snowblower build
   / snowblower build #1
ohiojeff
maumee ohio
na
Hello all. I have a Smyth six foot snowblower designed to operate on a 3pt. hitch and 54o rpm PTO. I want to rework it so it is self powered with a 30 HP Kohler engine. I am also going to fabricate a frame with casters that will attatch to the front of my Jeep. Obviously I will need to reduce the speed by way of an intermediate shaft with the appropriate sized sheave or sprockets. The blower now has the splined shaft that I will need to adapt to . Where is a good source to get such adapter and what is it called? Thanks P.s. Has anyone else done such a conversioin? I know they are commercially available but I dont have $7500 to spend on one.
   / snowblower build #2
You could use a short PTO drive shaft to couple the blower shaft to another bearing support shaft that has your spocket. You can get PTO shaft yokes for spline shafts and keyed round shafts. That may end up being too long for what you want.
Another option, would be to bore out a sprocket so you could weld in a spline shaft coupler such as this: 16302206 1-3/8 X 6 Spline Joints
Check out Farm Equipment, Mower Parts, Tractor Parts, Garden Supplies | Agri Supply and For Life Out Here | Tractor Supply Co. for other tractor PTO parts or check out your local tractor dealers to see if you can find something.
Good luck and welcome to TBN.
   / snowblower build #3
Try Tractor Supply they usually have a variety of different adapters that would fit the bill; although you may need to modify them.
I really don't believe that you will be happy with the performance of this setup for a few reasons;
1. Your 5hp/ft of blower with is traditionally accepted as sufficient but having said that with reduction and parasitic losses could be on the low side.
2. A 30hp Kohler will Guzzle the gas. A diesel twin may be a better choice
3. It may be way too heavy for the front of your jeep (balljoint, bearing failure etc etc)
If you decide to go ahead make sure to post progress of your build
Sent from my iPhone 5s 64Gb using TractorByNet
   / snowblower build
thanks , i will look at TSP. I should have stated also that I do not intend to travel down the road with the snowblower IN fact it will not be suspended by the Jeep. it will be in constant contact with the road ( driveway ) . Check out Sno Vac on the web. What I am doing will be essentially the same concept. thanks, jeff
   / snowblower build #5
I once used a 13 hp to drive a 4 ft blower. Used a 3" drive sprocket to turn an 8" blower sprocket.
The setup worked just fine, in fact overpowered, so 6' with 30hp would probably be fine.
At worst possibly 9 or 10 inch driven would do the trick.
You will absolutely need a tension set up as chains do stretch.
By my math, wanting 500 rpm at blower using the 13 hp is how I arrived at 10 and 3 ins and in fact I was probably turning the blower at 700 rpm or so. My biggest challenge was to keep the engine from digesting cold snow so some creative baffling was in order.
   / snowblower build #6
Here is a guy that basically did the same thing. Used a VW motor though and it was attached to a tractor. Check out his channel for other vids
   / snowblower build #8
Another one. Might be a better example.
   / snowblower build
Thanks for the input. So I'm wondering would belt drive be better than chain since as you said the chain would tend to stretch? Also I take it that your setup had just two sprockets, one on the engine and one on the blower. That may have accounted for the higher RPMs at the blower.? The one I saw on the web had on intermediate shaft that I'm guessing served as a speed reducer. It had a belt from the engine to the intermediate shaft and then a chain from the intermediate to the drive on the blower itself. Is the "tensioner" you suggested simply a means to take up slack in the chain? thanks again, jeff
   / snowblower build #10
Sure you could use an intermediate shaft but then you'd have 2 chains and 4 sprockets plus bearings and shafts and some structure.
Also add 2 adjusters.
You are blowing snow which is frozen water and when wet belts will want to slip.(and no matter how you build, snow will fly)
When I rigged my setup I mounted the motor on top of my blower with shaft sprocket lined up with the blower input shaft.
When the PTO shaft removed my blower had a short keyed shaft sticking out ready to accept the large driven sprocket.
I venture to say that all blowers will have a similar short keyed shaft setup as that is how the PTO shaft has to couple.
Brief shopping and you will find that any diam shaft combined with diam sprocket is available in different chain sizes.
Your driven sprocket can in fact be almost as large as the blower impeller and still clear.
As a tensioner you need a 3rd idler small sprocket on a pivot that you add pressure or tension to the slack side of the chain.
I think the chain generally used is # 40 but could be wrong..
Naturally the idler needs to run on bearings and a method devised to adjust.(hinged with longish screw)
I am sure belts could do the job but you'd probably need double or triple belts to handle the HP.
2015 Ford Taurus Sedan (A51694)
2015 Ford Taurus...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
COATS 8000 A HEAVY DUTY HYD TIRE CHANGING MACHINE (A51248)
COATS 8000 A HEAVY...
(2) 330 GALLON POLY TOTE (A51248)
(2) 330 GALLON...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
City of Lakeland (A51691)
City of Lakeland...
