Snowblower/Bucket widths for L3240 ???
   / Snowblower/Bucket widths for L3240 ??? #1
Yota_85
Western Mass
Kioti DK35se
In the Kubota brochure, it specs a 62" front and a 64" rear snowblower for the L3240.
It offers a 66" bucket for the LA514 loader and a 72" for the (stronger) LA724
Also specs a 72" front blade for the same tractor
All implements are the same with an L3540. (makes sense, as it is practically the same machine)
But, with R4 tires, I measured the width at a local dealer of 67" or 68" (depending on what you considered width. The 67" is how wide of impression I thick the "tread" would make in soft dirt)
I asked if the R4 were adjusted to their farthest setting, or if there was spacers installed. No for spacers and the width is not adjustable with R4s.
What's up with that? Implements narrower than the tread width? Especially snow blowers?
I have to be missing something. After that 72" blade is angled even a bit it MAY cover 64-66", still too narrow for the tractor.
Or is the literature misprinted?
Are 6' implements the norm for the 3240? If so, I'd think that'd tax the 25 PTO HP quite a bit, especially with a 6' snowblower or 6' rotary cutter.
Thanks for any light you can shed on this........
   / Snowblower/Bucket widths for L3240 ??? #2
I would think 6 or seven depending on the attachment. For buckets and blades it will depend on the work you're doing. If you're moving a big heavy bucket it may be to big for the loader to lift and you'll have to not fill it as full. Foe the blade it may work great in snow (depending on depth), but not as well in dirt. You'll just have to take a smaller bite. The snowblowers I'd look to see HP requirements. I have a 6 foot mower on my 3940 but am looking for a 7 foot to cut more with each pass. If you're looking to buy a new 3240 get the bigger loader 724 if available and the skid steer quick attach.
30008 (A53424)
30008 (A53424)
2013 Ford F-650 Flatbed Truck (A51692)
2013 Ford F-650...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A54757)
UNUSED WOLVERINE...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
