Snow Snow removing
   / Snow removing #1
spox
Hi all,
i have a kubota 2630 and the front mounted snow blower. We are going through some ice cycles here where the FEL would be great to have to remove the melting ice layers. I am being kinda lazy, but wondering, how much of the snowblower do i have to remove to put the FEL on? If I keep the quickattach on, will the FEL have enough clearance?
   / Snow removing #2
I was just out removing ice chunks today with my blower. By the time the FEL is on, the whole process could be completed with the blower. Of course, your situation may be different.
   / Snow removing #3
I don;t have one myself (front blower) but have read many posts with the same question and I believe you can use the FEL with the quick mount still in place...
Good Luck
   / Snow removing #4
The quick hitch comes off quickly and easily by removing the sliding lock pin at the rear and loosening the large T-bolt in the front. The right and left side brackets that support the quick hitch can be left on permanently and don't interfere with anything. Leaving the subframe on and mounting the FEL is a no-no.
   / Snow removing #5
On my old Kubota front blower, ice put a hurtin' on the shoot and deflector, basically creating dents from the inside out. I imagine your unit is a bit stouter, but I'm wondering how it is holding up to the ice and stones.
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
2019 Freightliner Sprinter 1500 Van (A50323)
2019 Freightliner...
UNUSED JCT SKID STEER QUICK ATTACH HAYSPEAR (A51244)
UNUSED JCT SKID...
UNUSED FUTURE MINI SKID STEER TRENCHER (A51244)
UNUSED FUTURE MINI...
Gleaner R50 Combine (A50514)
Gleaner R50...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A52128)
Texas Post Driver...
