snow removal with mini ex?
   / snow removal with mini ex? #1
76Acorn
Medfield Mass
Ford
Im a newby here. but have a quick question.Im considering how a mini ex with a plow or a blade would do on snow plowing (LEVEL GROUND)
Wondering if anyone has don't this way? Im also even considering putting a hitch of some sort on the blade so I can attach a fork set.Basically Id like the mini to do what the tractor does.
Thanks and nice forum..
   / snow removal with mini ex? #2
It would be painfully slow+the blades on a mini aren't very wide.But better than a shovel.
   / snow removal with mini ex? #3
I have a Volvo EC3500 and driving it in the snow is a hairy ride. Forget about using it on ice.
Fred
   / snow removal with mini ex? #4
Agree with the previous posters-slow and slippery-I have seen my brother take some rides with his CTL with rubber tracks.
Will
   / snow removal with mini ex? #5
I have a PC-50 (11,700 lb) with 2' bucket,rubber tracks and a 6'-ish blade. I use it to push banks (4 to 5' high) back on the 750 foot flat section of the drive by driving along the highest / deepest part of the bank using the blade to roll up the snow. I use the swing to clear out from in front of the blade and then push the bank off to the side with the bucket as I pass. It works pretty well and getting stuck is pretty much a non-concern but there are a couple of important points. One is my tracks are on un-frozen or just frozen leaf litter and not ice, I get very good traction allowing me to use all 10,000 lbs of tractive force on the blade - this thing will easily move a snowbank that stops a tractor dead. Two is I don't have a ditch on the side of the drive that I stack snow on. rubber tracks beat steel on on this surface. On hard ice, anything beyond 3 degrees of slope and the machine is a hazard, and you get zero traction - the bucket just pushes the machine around, and it's pointless to try and do anything. on snow it's pretty good. Ice is hard on these things as it will melt and freeze in and around the tracks and track motors when things cool off - I pretty much use it and then it sits until after the next thaw (but I do baby my machines a bit...) For just plowing it's extremely slow and quite messy - I used the rear blade of the tractor to clean up after bank pushback. I now use a rear mount blower and the mini-ex sits all winter.
GOODYEAR SET OF 420/85R30 NEW AG TIRES (A52748)
GOODYEAR SET OF...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
GENIE MAN LIFT (A52472)
GENIE MAN LIFT...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
