Snow Equipment Owning/Operating Snow removal with back blade
   / Snow removal with back blade #1
ThisldooFarm
Upstate NY
B7800
When removing snow from driveways with a (presumably) angled back blade, is it best to go forward or in reverse. Also, is it best to have the blade forward, or reversed? Thanks. Snow coming...
B7800
   / Snow removal with back blade #2
I find it best to angle the rear blade and go forward. It's a pain to look to the rear constantly. If you have a gravel drive I find it best to reverse the blaade as in the forward position it tends to dig in and remove the gravel. In the reverse position it tends to ride over the gravel. On pavement you can leave it in the forward position.
   / Snow removal with back blade #3
I used to operate in reverse. It is better if your blade's convex side is doing the snow pushing (less likely to dig in). Since mine won't rotate 180 degrees, reverse was my only option.
However, now I leave the blade about an inch above the gravel driveway and run forward. When most of the snow has been plowed, I'll do some final clean up in reverse, if necessary.
My drive isn't long enough (150' or so), so running in reverse isn't that much of a pain in the neck, but there's less chance of damaging the 3PH operating when running forward.
   / Snow removal with back blade #4
On the Rare occassion iuse the RB for snow removal , i drive forward, couse you are driving over the snow before u plow. a lot depends on the amt and type of snow. if it is only a couple of ins. and powder type i will use it, but mostly i use the FEL
   / Snow removal with back blade #5
I plow mine in reverse. I also use skid shoes on my blade to keep from digging into the gravel.
Solo
   / Snow removal with back blade #6
I have tried every method you described, all will work, but for me the most effect way is in reverse with the blade with cutting edge doing the pushing.
It does a strain on your neck but I have found it to work best.
   / Snow removal with back blade #7
Can you provide some more detail on what you will be plowing.
Thanks for all the input. The driveway, 500 feet, is asphalt, and I have a contract to plow it with a pickup. This is for the 500 foot gravel driveway to the barn, and paths up the hill to the manure pile, perhaps 1500 feet. Also, does anyone use a roller as they did in the old days? What type? Thanks.
   / Snow removal with back blade #9
"Thanks for all the input. The driveway, 500 feet, is asphalt, and I have a contract to plow it with a pickup. This is for the 500 foot gravel driveway to the barn, and paths up the hill to the manure pile, perhaps 1500 feet."
If I were you...
I'd drill a series of holes in the lower edge of the blade and attach a length of hard rubber (I've read of folks on TBN using some kind of horse stall matting, if I recall correctly) to the lower edge. If you can rotate your blade's mold board 180° (so the convex side is facing the direction of travel), do that. Then operate the tractor in a forward gear with the rubber in contact with the asphalt drive.
For the gravel and paths, lift the blade an inch above the surface and, again, operate in a forward gear.
The matting would take all the wear and reduce the amount of gravel you pull.
The blade should be set at a 30° angle to the direction of travel.
I'd start clearing when the snow accumulation was about 8". Your tractor should handle that fairly easily. This depends on the snow, of course. A heavy wet snow may give you some grief if you wait any longer. That Kubota is a nice machine, but it's a bit light. What kind of tires do you have...and do you have chains?
That's what I'd do...
   / Snow removal with back blade #10
I use mine in both directions depending on the snow and driveway conditions. I have a gravel drive.
Until the ground has frozen I use the rear blade with the cutting edge facing away from the direction of travel, reversed. Most times I push the snow in reverse on rare occasions I will angle the blade but the blade turned cutting edge away does not wing the snow off to the side as well as it does with the cutting edge forward.
Once the ground is frozen if the snow is light and dry and under 8" I angle the blade about 30 degrees cutting edge forward and drive forward pulling the snow. When the snow is wet or over 8" the blade is turned cutting edge towards the rear and I drive in reverse with the blade at about a 30 degree angle pushing the snow.
One problem with rear blades is they don't wing the snow up as high as a snow plow on the front of a truck would. Once the snow banks get to a certain height it is hard to push snow up and over them. When this happens I put the cutting edge facing backwards angle the blade about 25 or 30 degrees but leave it raised up a foot off the ground and back along the snow bank pushing the top back.
I hope it is a good long time before anyone has to move any snow.
Randy
3014 (A50657)
3014 (A50657)
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A52128)
Morooka MST 660VD...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
Toro 3100D (A50324)
Toro 3100D (A50324)
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
