Snow removal with a loader?
   / Snow removal with a loader? #1
dsnyder
Although I only have an acre to mow, I'm doing my hardest to come up with justification to buy a nice, new BX series with a loader. There are a number of landscaping projects that I would like to tackle as well as some re-grading of my gravel driveway. I also need to plow snow in the winter and I was wondering if anyone used their loader for snow removal? My driveway is about 60 feet long with a 25 X 45 foot parking area at the end. It's gravel so it doesn't really lend itself to a blade....
Help me justify a BX!
   / Snow removal with a loader? #2
Sorry but the snow removal aspect won't sell unless you want to use it for pushing back the banks afterwards. I'm in Syracuse NY (AKA lots of snow) and wouldn't do my driveway just with the loader bucket. 1st pass is fine but after that all you wind up doing is pushing the stuff around since you can't angle the bucket. I also have a lot of gravel area to do and DO plan on getting a bcak blade to do it. Just plan on keep the blade high and not "scraping to the bone". All that said GET THE LOADER ANYWAY! You'd be surprised how much you use once you have it. Really worth the cost if you can swing it.
   / Snow removal with a loader? #3
Last winter, my BX came in before the loader. The dealer (Frederick Kubota in Frederick, MD) lent me a 5' rear blade to use in the mean time. Then the snows came. Three major storms. Found out what everyone on this forum was expressing at the time, a rear blade is the way to go! Turn the blade around, and go backwards. No chains, no problems. No snow sticking (a problem reported with loaders). I have an asphalt drive, but I plowed a neighbors loose gravel drive. Kept the blade a tad bit higher, worked great. The cost of a basic 4' or 5' reversible blade is a nit compared to the cost of the tractor (Tractor Supply Company, for example. Less than $200).
I also agree with Gerard, get the loader anyway! You will use it.
Rationalization for the BX… because it will do what you expect from it, and more.
   / Snow removal with a loader? #4
Ahhh it seems you have been bit by the Kubota bug./w3tcompact/icons/wink.gif
I rather use a plow on my long drive than unhitch the plow from my bucket if need be to remove piles of snow if need be.
For me it takes longer w/ a front end loader,and getting cold takes the fun out of tractor time./w3tcompact/icons/frown.gif
I'm going to take a step and say your going to buy tractor real soon. /w3tcompact/icons/wink.gif
Take care and stay safe /w3tcompact/icons/cool.gif
Thomas..NH
   / Snow removal with a loader? #5
To me, some of getting a tractor is economics, but a lot is just 'I want.' I went through the economic justification thing and belaboured my wife with cases for this and that. She finally said something like: 'You want a tractor? If we can afford it, then just get a tractor.' I guess she could have added that quite a few people get cottages because they want them, and then don't spend enough time there to actually JUSTIFY them.
Tractors are nice things to have. I suppose some economics should be there, but I'd put the idea of a tractor on the 'I want it because I want it' list. On the economics side, I figure I'm getting enough justification if I keep the tractor busy something over 100 hours a year and use it for around 90% of work I'd otherwise contract out. The 90% figure sort of determines a desirable sized tractor. Too small, and most of the larger jobs get contracted out. Too big and too many things can't be done due to maneuverability and turf damage problems. I've got a 24hp tractor and two 1-acre lawns with landscaping to mow. I still use a riding mower for the lawns, because it takes longer to maneuver the tractor around buildings and landscaping than just using the riding mower. The tractor also doesn't do nice things to the turf during wet spells, even with turf tires. However, the tractor earns its with its plowing, digging and material handling. Besides, I wanted it. In addition to its uses, it's my toy. I went with the tractor, and didn't get an ATV, snowmobile, boat etc--at least yet. I figure that I use the tractor more than I would all of the other sorts of toys taken together, and I accomplish something more than just recreation as well. From that perspective, the tractor seems like a bargain. However, I did get a used tractor so I could get enough implements to keep it busy.
Regarding your questions about loaders: If you have one, you'll use it a lot, but loaders really aren't very good at either snow plowing or grading, or digging for that matter. Using a loader for plowing and grading is a great way of putting a lot of hours on a tractor. Well, maybe a lot of hours would justify the purchase, but I'd rather go with: 'I want it and it's useful too.' I guess my conclusion is to get a tractor mostly because you want one, but get one and enough implements to make it really useful. Fighting with the tractor while trying to use the loader for jobs it isn't good at isn't fun for very long. Oh, a blade on gravel is fine after freeze-up. Skids help, but gauge wheels are better. Before freeze up, I use the loader with the bucket curled back and the lift floated. That works better for me than trying to hold a blade or blower off the ground.
   / Snow removal with a loader? #6
I am going to disagree with everyone so far. I use my tractor to plow snow and I have absolutely no problems whatsoever. Sure, it would be a little quicker with a plow, but I have a 1200'+ driveway plus a large parking area at the top, and get a lot of snow (New England).
I was going to buy a blower, but figured I'd try one season to see how it went first...now I know I don't need a blower.
It may be true that a small tractor is not very good, but I can push a *lot* of snow with my 6 ft bucket on my JD5410.
Have fun.
2025 New/Unused Wolverine 32in Hydraulic Backhoe Excavator Thumb (A51573)
2025 New/Unused...
2023 Globe Booster Flipaxle (A51572)
2023 Globe Booster...
NEW Wolverine 36'' Skid Steer Grapple Bucket (A53002)
NEW Wolverine 36''...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
