Hello. After a long time reading information on this forum I am getting closer to buying a Kubota B2650 or something similar. I need a tractor primarily for loader work like moving soil for garden beds and landscaping. I also need to move a bit of snow. I am looking for some advice from those with experience.
First some background. We live in northern Alberta and are trying to get lined up to build out on my parent's home quarter where we have our garden, chickens, and so on. My wife and I want to get out of town before we retire which is still a fair ways off but coming quicker. I have been using either a JD LX188 with a 38" front snow blower or my Rhino with a blade with home made hydraulic raise and angle to keep the yard clear for my retired mother up to this point. The gravel driveway is a u-shape and is about 500 feet long plus some other trails in the yard. Once we build there will be a fair bit more driveway. The Rhino is far faster but at some point pushing I eventually run out of room, especially after a good dump of snow. I also believe that plowing puts a lot of wear on any brand of UTV so I want to use it less for this. The snow blower can remove the snow but it is a relatively very slow process and nasty when the wind returns that same snow into my face. The steering on the JD LX188 is dreadful with the snow blower down as the skids force it to continue going straight. If it is raised enough to prevent this there will also be enough snow left to end up with the tractor stuck. It tends to get stuck fairly often. Yes, it has rear chains and weights. I also do realize this is a lot different tractor than the Kubota.
So I have to make some large decisions:
1. Get the B2650 with a loader and SSQA angling blade set up. How well can they push snow? I think I would get chains regardless of what I am using. This would be the least expensive and least likely to cover me in snow. No, I cannot afford to go with a cab and for the use in the summer I would rather not have one.
2. Get the B2650 with a loader and front snow blower. Will these tractors steer better or is the relative size of a front blower such that the skids still act as railroad tracks heading straight and resisting all steering input?
3. Get the B2650 with a loader, a rear snow blower and maybe the angling blade on the loader. Less money in the blower by far which balances out the front blade cost, less convenience due to backing up more, better steering control perhaps, and the loader is still useful during the winter. This snow blower would be mostly for emergency use when I couldn't push anymore.
4. Forget the B2650 and buy something a bit larger with a loader and angling blade and not need the snow blower (and that money buys the larger tractor). I know at some point a tractor and bucket or blade is big enough to overcome any snowfall but money becomes an issue really quickly.
5. Maybe forget the angling blade on the loader altogether and get a heavier duty 3pt blade to plow lighter snow (which could also act as a rear ballast) and use the bucket to push and lift the heavier snow when needed.
Also which tires are better in snow and ice? R1 or R4? (I will never use this tractor for mowing as we have two riding mowers that are cheaper to wear out and cut 48" and 54" each.) I would likely use chains on the rear with either type of tire. Chains might be nice on the front for steering but I would hate to do damage with front chains and steering components if they come off or make contact during a turn.
I have looked at so many other options that I don't know which way is up, even to the point of converting a rear snow blower to mount on the SSQA and mounting a gas engine right on it. I could do this as I can fabricate and weld fairly well but I am learning that these projects always end up being more expensive than planned.
I would appreciate some input from those of you who have been down this road.
