Billrog
Veteran Member
- Joined
- Dec 9, 2014
- Messages
- 2,054
- Location
- Armstrong, British Columbia
- Tractor
- Kioti 2610, 580 SuperM Case Backhoe
Well looks like I'm getting the opportunity to see how well the traction is with turf tires on my new Kioti . Yesterday with 6" of fresh wet heavy snow all went well only slid down 1 hill backwards once when I got on straight ice. Having only put 1 hr. on it so far today I get a chance to practice a little more getting use to the controls. Living on a mt. with a long steep driveway I only have ever used chains under extreme icy conditions in the past. So far this tractor has preformed very well with the turf tires . I use a 7' back blade and the bucket to push the piles back or scrape through compact snow. I don't find the hydro-static ft. lever as convenient as the one I'm use to as it's so far forward my foot hit the break pedal often which is very close. I'll see how it goes after a few more hrs. before getting carried away with modifications. The pic. is where we come up to the house and go down on the other side there's only 3 switch backs to deal with the rest is a straight run maybe 1/2 to 3/4 mile altogether. 1st yr. without a cab and you can be dam sure I'll have one built before next winter. Took pick this morning.
This was last yr. s. side of the house when everything was ice with chains on the old tractor.
Much better plowing when it's cold than just around freezing.
