snow plow
   / snow plow #1
qed-cat225
Sullivan, WI
2011 Bobcat CT235
emailed my dealer today about looking into the snow plow...apparently bobcat no longer makes the lift kit required for the plow or front snow blower....do any of the other colors offer something comparable?
   / snow plow #2
Did the dealer check to see if there were any at other dealers? It probably takes 20-30 minutes to put a subframe and attachment on. The Kioti blade should fit. I had a blower for my Bobcat. After having it I am not that crazy about tractor specific attachments. if you get rid of your tractor it probably won't fit your next one. Mk martin makes a subframe blade. MK Martin | Front Mount Kit I am not sure if Meyer makes a subframe blade. If you could find a truck plow with the pump you could adapt the whole assmebly to your tractor for a subframe setup.
Here is my old Bobcat and blower.
   / snow plow
found one from Michigan Iron as well, however it looks like Kioti does not offer the blade any longer either. guess I will look for a simple skid loader attach version for my loader
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A52141)
2015 VOLVO VNL...
2011 JCB 541-70 TELESCOPIC FORKLIFT (A51242)
2011 JCB 541-70...
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
2011 Nissan Rogue SUV (A50324)
2011 Nissan Rogue...
2003 STERLING ACTERRA ROLLBACK (A51222)
2003 STERLING...
