Snow snow plow on loader arms?
   / snow plow on loader arms? #1
TIMinPa
pa.
mahindra 3510
wanted to know of the cons to mounting a power angle snow plow inplace of my bucket on my 3510 hst tractor. will the side pressure damage the loader arms/ cylinders? anyone out there done it?
   / snow plow on loader arms? #2
Take a look at the Kasco and Curtis sites. They both offer Quiktach and pin mount blades for loaders. These are in the $1500 plus range. I am planning to mount an ATV blade to my bucket or make a pin mount for it. I think I can do this for under $700? I too was concerned about the stresses you mention but according to the folks at Kasco you need to be sure to size your blade to your loader. Too long and you will get the side stress you mention. I have a Woods 1006 loader (small) and Kasco recommended a 54" blade. There are also the clamp on type (Snow Champ) that are available in Albion PA. There is just somethin about the clamp on type that worries me though. I can see the lip of my bucket being stressed. I know a guy near me that had/has a Curtis 5' pin on for a Kubota 7500 for sale. I looked at it and it is like new. I think $1000 might do that one if he still has it. PM me if you want his number. He is near Oil City. You would probably have to move the pin mounts to suit your application.
thanks for the info. will check the site out for size, will make my own mount when i find a blade. have one on my 52 willys that i may use without power angle pipefitter/ millwright by trade so i can make my own mounts wife loves running the tractor more than my old massy!!! but says she won't plow snow, so i guess i get to run it next winter!!!!!hahaha
   / snow plow on loader arms? #4
Tim
You will need at least a 7' blade to cover the width of your tractor and you will have to add weight to the front of the tractor. Actually I would load all 4 tires to plow as the front of the tractor will want to slide side ways when plowing with plow angled. Good luck with it.
   / snow plow on loader arms? #5
Tim,
I plow snow with a 7' blade on the loader arms .(a 35 HP tractor)
As long as the plow has trip springs if you hit a solid object you will not have any problems.
   / snow plow on loader arms? #6
DK35vince said:
Tim,
This is not a suggestion, it is a must. You will mangle your loader if you hit something with side load forces.
2016 CATERPILLAR 336FL EXCAVATOR (A51242)
2016 CATERPILLAR...
2007 INTERNATIONAL MA025 DAY CAB (A51219)
2007 INTERNATIONAL...
International 574 2wd Tractor (A52128)
International 574...
2016 PETERBILT 587 (A50854)
2016 PETERBILT 587...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
2015 CATERPILLAR 272D2 WHEELED SKID STEER (A50458)
2015 CATERPILLAR...
