snow plow hyd
   / snow plow hyd #1
bullwinkle
I have a question to you folks that are knowledgeable about hyd. I have a NH TC-30 with FEL. I also have a snow plow which i adapted a quick attach to for use on the TC. Of course I need to raise and lower the plow but can I use the bucket "roll" lines to angle the plow? I would set the plow in the desired position and then connect the plow to those lines. will this work? Will the bucket roll cylinders hold in position? The system is in good shape and nothing leaks down. Thanks
   / snow plow hyd #2
Welcome to TBN:D
This has been discussed a lot here if you search around, but:
Yes, no problem. Just attach the line from each off the cylinders to the dump/curl circuit. Be sure to clean the cylinders out first though...
It will work, but you may experience leakdown with the weight/length of the plow versus the empty bucket. Also, it will be hard to set the "roll" and then get the QD's disconnected because they will probably have pressure on them when it's set where you want it.
Search for these terms:
snowplow
FEL snowplow
FEL plow
I had one myself but was never happy with it...I have since got a frame mounted plow and am a happy plower:D
   / snow plow hyd #3
your dump/curl cylinders will not stay in place long. You will have to use some kind of chain to hold it in place. Another option is installing a 3rd function or diverter on your loader so you can use all the functions without having to worry about chaining things or disconnecting hoses and reconnecting hoses to do what you have to do. There are many threads on here discussing those options. I started to add a 3rd function to my loader but have had to put it on hold for a while as other thing came up.
   / snow plow hyd #4
I have a 3rd function run up to my FEL plow. I think you will find that you will want to adjust the curl. I'm very happy with my plow. Can't float it but as long as you keep a little weight on the front wheels it has never pulled to the side and with my wings mine is 90" wide.
   / snow plow hyd #5
I am assuming that the New Hollands are different than the Fords with the 'Regen" circuits? I tried this , and it wouldnt work, just like the dealer said it wouldnt becasue of the 'regen' system.
   / snow plow hyd #6
Just thinking out loud here, how do the cylinders leak down when there's no place for the fluid to go when the lines are disconnected?
With my loader as long as it's running there is almost no leak down but if it's off you can almost watch it go down I'm assuming the fluid is going back into the system, but if the lines were disconnected?
It would be a pretty heavy load with that plow way out on front, seems like something would try and give.
I like the chain idea to keep the plow from dumping forward, not sure what you would chain it to though. but if you could get a fixed position you'd be all set, no need for the 3rd control up front.
   / snow plow hyd #7
leakdown can happen one of two ways, the valve can let hyd fluid leak through it, or the seals on the end of the shafts can leak and let fluid go from one side to the other. in a newer tractor I would suspect the valves (or the pressure relief valves in them) as being the culprits.
Aaron Z
   / snow plow hyd #8
After I posted that last night I was thinking the only place for the fluid to go is the other side of the cylinder when the lines are disconnected.
I just about ready to graduate from hydraulics school, kindergarten!
I am learning and am almost ready for 1st grade.
   / snow plow hyd #9
I think you will become quickly frustrated if you don't hold the blade curl either hyd. or physically.When you start applying any force on the blade its not going to stay in the positon you want or need.
Sincerely, Dirt
   / snow plow hyd #10
Other people with Fords and NH tractors are running snowplows, both factory and homemade setups. Are you saying that the regen cannot be locked out on Ford/NH machines? The regen is active through the whole joystick throw?
How are others doing it then?
Nissan CF60 6,000lb LP Forklift (A51691)
Nissan CF60...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A53472)
2004 Capacity Yard...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
WESSEX RMX500 LOT NUMBER 45 (A53084)
WESSEX RMX500 LOT...
2007 Chrysler Pacifica SUV (A51694)
2007 Chrysler...
