Snow Blade Snow/Plow Blade for Case IH 275
   / Snow/Plow Blade for Case IH 275 #1
Kurtrado
Case IH 275 - Turf Tires
With a Case IH 275 31 hp 4WD Compact Tractor, there is a rear mounted hydraulic valve that can be routed to the front of the tractor to support a hydraulic blade/plow. I was wondering if anyone knows of any plows or blades that can be modified or are compatible with the 275 and any tips for mounting, hydraulic vs manual tilt, and problems with the setup in general.
   / Snow/Plow Blade for Case IH 275 #2
I would think that to find a factory blade for that tractor might be tough with the age of it! So the options are what would be adapted to it and your ability to do the job.
You talk of a valve to operate it but I believe i would only be a singel spool so that would limit you to up and down only without the addition of a splitter to operate a hydaulic angle with the lift being used for the primary spool.
It would allow for up and down hydraulic lift but not tilt. Tilt would have to be manual for the set-up to work. Thats what I am leaning towards, finding a manual tilt hydraulic blade/plow and modify it to fit the tractor. Thanks for the reply
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A51039)
Kubota 24in Quick...
2013 Ver-Mac Solar S/A Towable Trailer Message Board (A49461)
2013 Ver-Mac Solar...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
80in HD Tooth Bucket with Side Cutters (A51039)
80in HD Tooth...
PALLET OF FUSION EQUIPMENT (A50854)
PALLET OF FUSION...
1049 (A50459)
1049 (A50459)
