Snow Equipment Owning/Operating Snow chain questions
   / Snow chain questions #1
Pks
Platinum Member
Saline, Michigan
Kubota L3700SU, Cub Cadet 1430, Hustler Super-Z 66in, Vermeer 1250
Will snow chains with studs severely scratch concrete and/or black top drives?
How rough is the ride when using 2 link ladder chains? I've used 4 link ladder chains without studs and I thought I'd like a bit more traction.
I don't want to put divits into an asphalt driveway and I'd like to avoid such a bumpy ride out on the backtop road.
Do any of you folks have any good words?
   / Snow chain questions #2
I have a B7510 Kubota with R4 tires and I use 2 link ladder chains on the rears only. It is a little bumpy on pavement, you definately feel them, but it does not bother me. There are a few "white" scratches on the driveway and they will be more defined if you spin the tires. I don't have studs on my chains, if I did I'm sure I would chip up the pavement. My chains weigh about 30 lbs each.
   / Snow chain questions #3
I'd also avoid the V-bar/studs for use on hard surfaces as I think they'll mark; less so obviously if you get continuous cold so can leave a packed base to protect the drive. I always thought 2 link chains to be smoother than 4 link as there's more or less always some chain under the tire so less bumpy.
In my part of SE Michigan, the snow tends to melt on the black top and concrete surfaces a few days after it snows so there's no real cushioning effect.
Your mention of the 2 link ladder chains supports my initial theory about a smoother ride vs the 4 linkers that I'm familiar with. They were not bad, but they lacked traction and the v-bars my neighbor has seemed REALLY rough.
   / Snow chain questions #5
www.tirechains.com also supports that theory. One of their selling points for 2 link ladder chains is a smoother ride on pavement.
   / Snow chain questions #6
I'm in the same dilemma. I'm about to order chains for my DK45 but i have some concrete and some asphalt and alot of gravel to consider.
I guess I'm leaning towards the 2 link, but I'm still unsure what to do. Ill probably chain up all 4 tires.
   / Snow chain questions #7
Keep the chains tight,plus take wide turns if you can.
I see the 2 link ladder chains at 'tirechain' to be about $300. Are there any other suppliers that might have a better price?
   / Snow chain questions #9
They are not cheap but these are suppose to work well on pavement. I almost bought a set but since I have no pavement and the only cement is the floor in my garage I opted for a more aggressive chain.
Aquiline Multi-Purpose Tire Chains
Crazyal, if you went with a more aggressive chain, what did you get and how do you deal with your floor?
Simpson 3400 PSI Pressure Washer (A51573)
Simpson 3400 PSI...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2017 Club Car Carryall 550 Electric Utility Cart (A51691)
2017 Club Car...
NEW 36'' Skid Steer Grapple Bucket (A53002)
NEW 36'' Skid...
66 Tomahawk Skid Steer Bucket (A52384)
66 Tomahawk Skid...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
