Snow buildup
   / Snow buildup #1
dj1701
Veteran Member
East Concord, NY
John Deere 4320, Kubota BX2680
Hey guys,
What do you all use to keep snow from sticking to your implements? I used Silicon last winter, and it was better than noting. Hope to find something better.
Dave
   / Snow buildup #2
I use fluid film and it doubles the throwing distance for my toro snow pups.
I don't bother spraying and wiping down shovels with it as you cannot keep the snow
on the scoop long enough to toss it away.
Fluid Film is made from the Lanolin taken from sheeps wool and it is not
toxic to use in either the liquid or aerosol form. The propellent is non toxic too.
Don't buy any of the aerosol stuff sold by the dealers or the big box stores as
it has a brood herd of toxic ingredients in them and your lungs will not like them.
In a pinch you can use the big less costly aerosol cans of no stick cooking spray from sams club too.
   / Snow buildup #3
I’ve tried everything over the years. Only thing that works for me is a small crowbar. Can scrape out packed snow, chunks of ice, clogged snowblower chute, etc.
   / Snow buildup #4
Friend of mine once told me butter flavored Pam. I questioned why butter flavored?
He replied “ low cholesterol !”
   / Snow buildup #5
Hey guys,
Dave
A heated garage works best. Lacking that scrape the snow clean after each use. Windshield washer fluid helps break up compacted ice. Rain-X helps prevent some initial stick but wears off fast.
   / Snow buildup #6
Good topic! This will be my first winter with a blower and since the tractor is parked in a carport my plan is to scrape the blower clean as possible outside, then park in the carport with a couple of those halogen lamps to generate enough heat to melt what remains. If that doesn't work I'll have to unmount the blower and push it into the heated garage; there's not enough clearance for the cabbed tractor to fit.
Pete
   / Snow buildup #7
A friend uses Murphy's Oil soap on metal roofs. ??????
Thawing or melting, well a heated shop is the ultimate, but then I've seen the warm machine and implemts cause immediate sticking upon entering the snow (straight out of the heat).
   / Snow buildup #8
   / Snow buildup #9
That heated garage is actually counterproductive to using the impliment. The warm metal melts snow & then you end up with slush or ice to deal with. A cold plow or blower has less snow sticking to it. Nice to melt things off & not have things partially melt then re-freeze on you. But that's only half the story.
   / Snow buildup #10
Heard people using many types products Pam spray ski wax deicer etc, I've yet to find anything does really good job.
Kubota SVL95-2S Compact Track Loader Skid Steer (A50322)
Kubota SVL95-2S...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
Alloway 1315 10"x61' Transport Auger (A50774)
Alloway 1315...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A52141)
2015 VOLVO VNL...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A51692)
2005 Toyota Tundra...
2013 John Deere 2210 Accudepth Field Cultivator (A52349)
2013 John Deere...
