Snow Attachments Snow blowers and TPH lift arms
   / Snow blowers and TPH lift arms #1
Tig
Veteran Member
The County, Ontario, Canada
Kubota, B7100HST-D
How much play should be in the TPH sway turnbuckles? Currently I have left them just loose enough so I can wrestle an implement on. As I was blowing snow for the first time this week I found that the blower would swing left or right with the tilt of the tractor. Our lane is very narrow at some points, so I would like to cut it close to edge. At the same time I don't want to be bouncing off rocks or knocking then loose.
Is there any harm in tightening up the buckles to remove most of the play?
   / Snow blowers and TPH lift arms #2
I always ran my links/chains snug on my blower (and most other impliments). Always meant i needed to loosen them to change impliments though. As long as they rotate on the same axis (pin/shaft) as the lower arms, i don't see where you'll have any problem.
   / Snow blowers and TPH lift arms #3
I set mine so there is about an inch of play back and forth. I don't know if yours is the same but my freeplay changes between full up and down position. You have to check the play in both full up and down position so its not too tight.
   / Snow blowers and TPH lift arms #4
I second that. One of my tractors tightens up quite a bit as I raise it, which is awesome on rough ground or for precision work if you adjust the chains right. You can raise the implement up to the right height and have NO slack in the chains, so no slapping or slamming back and forth. It removes the idiot-proofness out of the tractor though, because you can break your 3pt lift arms if you raise them all the way if you're got them set up like this.
Billy Goat Blower Paint Dryer, 6.5 Briggs (A52384)
Billy Goat Blower...
2014 Ford F-150 Pickup Truck (A51692)
2014 Ford F-150...
2016 JOHN DEERE 8245R LOT IDENTIFIER 169 (A53084)
2016 JOHN DEERE...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
(4) 5 LUG GRAND PRIX ALUMINUM WHEELS (A51248)
(4) 5 LUG GRAND...
Two Post Car Lift (A50120)
Two Post Car Lift...
