snow blower
   / snow blower #1
tman1020
Veteran Member
north west indiana
Bobcat ct225 and Bad Boy zero turn
I'm looking in to a snow blower and trying to deciede between three point mount and front mount. i was wondering if on a ct 225 if anyone knows if the front mount (72 in) requires the removal of the backhoe brackets to install. (just the brackets i know that i would most likely have to remove hoe). also any opinions on sizing or which may be better i would welcome. thanks
   / snow blower #2
I don't know about your backhoe brackets but I would strongly consider the front snow blower if it will work for you.
With the cab and a front snow blower you'll have a true snow fighter machine.
Are there still some Bobcat snow blowers on dealer lots? They struck me as very well built.
   / snow blower
Yes there are still some around but I was looking at a used one. Problem is they are not supplying all parts for them.
   / snow blower #4
I have a CT335 with cab equipped with a Bobcat snow blade on the FEL and a 72" Bobcat snow blower on the 3pt hitch. I use the blade mostly until the snow banks start to get too high, then I windrow the snow into the center of the driveway, then come along with the snow blower to remove the windrow. Using the snow blower early in the season on a gravel lane-way usually ends up breaking a shear pin on snow blower as it picks up stray rocks and debris. Waiting until there is a nice packed layer of snow, really saves wear and tear on the blower.
   / snow blower
Thanks for that I am leaning toward the rear mount so I can keep my Loader on. Just checking out the wood Maxsnowblowers today online they seem pretty stout. They recommend a five footer for my horsepower at the PTO but I would be tempted to get a six and just go a little slower. I'm sure the bobcat blowers are nice but even with discounts there still priced higher then namebrand locally produced blowers that are still in current production. Sounds kind of sketchy getting a discontinued blower for a discontinued tractor and expecting to be able to find repair parts.
   / snow blower #6
Tman1020,
Last year I purchased the Woodmaxx SB60 (5 ft.) snowblower, well built very heavy, solid. I had the electric snow shoot installed very pleased all around. You will not go wrong with the woodmaxx 5 ft should be fine.
   / snow blower
How many PTO horsepower do you have on the tractor that you run it on and do you think you could've handled a larger one
   / snow blower #8
I had it on a John Deere 855 24 HP with 19 at PTO, as I said it did well but would not have gotten any thing larger. I see the BobCat isn't rated much more at the PTO I believe it is 27 and 19.5 at PTO. I did get a larger 32 HP I will be using it on this year. But as I said very well built.
   / snow blower #10
Hope it helps. Let me know if you get the WoodMaxx and how you like it.
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
2020 Ford F-150 XLT (A50120)
2020 Ford F-150...
2008 Ford F-250 XL (A50120)
2008 Ford F-250 XL...
2023 CATERPILLAR 259D3 SKID STEER (A51246)
2023 CATERPILLAR...
Electric Mobility Scooter (A51694)
Electric Mobility...
43002 (A51691)
43002 (A51691)
