Snow Attachments Snow blower shear bolt
   / Snow blower shear bolt #1
Deerlope
Veteran Member
Northern, New York
Kubota L3830 03: RTV 900
The new shear pins that I ordered came in today and the heads are marked like a standard GR 5 bolt but as I am learning and doing searches I find that not all GR 5 bolts shear at the same force. Does anyone have a model L-2174-62" Kutbota snow blower who would be willing to look and see how the shear pin is marked that is on the auger power shaft? I think that I am getting the run around. The dealer gave me the new bolts but I informed him that, that was not going to releave him of the responsiblity of repairing the auger.
   / Snow blower shear bolt #2
Deerlope, I don't have the same blower as you, (I have a B2660) but my guess is that they use the same augers and shear pins. When I got mine I changed both of the bolts to grade two. I figured I wanted to change bolts more often than brake something. I have only snapped one so far this season. And that is after hitting something that was buried in the snow. I would just use the softer bolts and not worry about the shear factor of different makers of grade 5 bolts.
   / Snow blower shear bolt #3
I have an L3830 HST with the same front-mounted blower. I maintain 2 miles of mountain road in Northern Idaho with it, front & rear chains, and a 72 inch Landpride rear blade. I have about 80 hours on the blower and have sheared at least a half a dozen grade 5 bolts (my road grows lots of invisible rocks). I carry a bag of shear bolts and tools with me every trip I make up and down the road. Two separate Kubota dealers told me to just go to the local hardware store and buy them as they are just standard, 1 ea., grade 5 bolts. So far the setup has worked and continues to work great.
   / Snow blower shear bolt #4
Deerlope,
I'm with Von. Grade 2 bolts will work fine until you hit
something. I have broken one bolt in four years.
I have the 59 inch yellow snowblower on front of a green
4310 but I sure admire the orange stuff too!
RHINO X1406 LOT NUMBER 64 (A53084)
RHINO X1406 LOT...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2023 John Deere 8R410 MFWD Tractor (A53472)
2023 John Deere...
2018 Ford F150 XL (A52384)
2018 Ford F150 XL...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
