Snow blower on Case DX40
   / Snow blower on Case DX40 #1
Jimmy Joe
Medford Wisconsin
I have zero experience with 3 point snow blowers, I found a 7 foot Arps twin auger blower looks to be in good condition owner says it works good. Will my tractor handle it or should I keep using my snow pusher? I thought if I ever pave the driveway a blower would be a lot friendlier to the surface plus no banks. The tractor has roughly 35 pto horsepower with hst transmission.
   / Snow blower on Case DX40 #2
Besides the horse power requirements you need to consider the blower weight and the distance the weight is from the 3pt hitch otherwise even if you can lift it, the front wheels of the tractor may be off the ground. You need to consider the height of the pto at the blower versus the height of your pto shaft. A pto shaft running at much of an angle has a short life.
Take the time to look through the Smyth Blower technical document as it has a lot of info on pto shaft angles.
84-S & 96-S (Agricultural) | Smyth Welding
I think you can manage the blower power wise by being careful. I would remove the upper auger to reduce weight and parasitic power loss as you could never run the blower with both augers fully in the snow as your power availability is marginal. The HST will be a help to match the blower to the power.
Dave M7040
Thanks Dave, you post some really good points I had never thought of. I wish I knew the weight of the blower, but I think it would just too much for my tractor. Money would be better spent on a new one sized for the tractor.
Jim
2012 Toro Greensmaster 1600 Walk Behind Mower (A48082)
2012 Toro...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
Year-A-Round 550 Gravity Wagon (A50774)
Year-A-Round 550...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51573)
IMPORTANT PLEASE...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
