The challenge with the puller idea is what is the puller going to push against.
When I removed the fan on a McKee 720 using a puller, I got a series of different length grade 8 or the so called grade 9 bolts. These went into the bolt hole in the center of the fan hub which secured the fan to the gear box shaft.
I drilled a small hole/depression in the bolt head to keep the puller center pin in place
To start with you want these bolts to just be proud of the fan hub when you start to pull.
Using as short a bolt as possible limits the likely hood the bolt will bend sideways as the puller pressure increases.
Once the fan starts to come off the shaft, use a longer bolt and pull again. Repeat.
On another blower this summer, which was only 4 years old, two rose bud torches and 2 steel tree felling wedges sledge hammered between the fan and the housing, a hydraulic buck bill spreader and a serious chain style come a long could not get it to move. It cost me about $1,000 at a specialty shop to have the fan removed, a few cracks welded and an oil seal changed. They had to build a special frame to apply a hydraulic puller's 10 ton pull to the blower frame. They thought the gear box was going to fracture under the load.
I would consider leaving the twine in place after removing all I could. The worst that could happen is a seal is damaged and then the fan has to come off. Pour some battery acid on the twine if your wanting to be more aggressive.
Trying to remove the fan is the last thing I would get started into at the beginning of winter. If something gets bent or broken you are done.
Dave
M7040
