Hi,
experienced back yard mechanic but a novice when it comes to roll pins, so I could use some thought from someone who is.
I have a NH TZ25DA tractor with a NH 50CS front mount snow blower attachment. For the second time I have somehow damaged/lost a roll pin in the drive path. Starting from the auger back toward the mid PTO drive, here is what I have:
The two augers are on horizontal shafts that are driven my a gearbox. The augers are attached with shear bolts. From the gearbox, another shaft runs back toward the tractor, and the secondary thrower (fan) is attached to this shaft with a shear bolt. This shaft drives a gear on the back side of the blower, which is connected to another gear/driveshaft** with a chain. This driveshaft connects to the quickhitch to be driven by the mid pto driveshaft. So it goes driveshaft from blower->gear->chain->gear**->driveshaft**->quickhitch (to POT driveshaft)
The gear/driveshaft** is a part that is offered by NH as only an assembly (H40C12). However, the gear is/was connected to the shaft with a roll pin. The first time it broke it looks like the pin sheared. I found a roll pin that seemed to fit, but my dim memort tells me it might have fit looser than I wanted (SAE vs metric?). Since they are not separate parts there is no spec on the roll pin size. The second time (a couple years later and a couple days ago) when the snow stopped blowing, I took a look and the pin is gone.
I am almost 100% positive this pin was never meant to shear, as there are shear bolts on the augers and the fan. Right? I also am betting I put a pin in that eventually worked itself out. I imagine since these tractors were built overseas, the roll pin must be metric, right? Also, are their different hardness/ratings on these pins?
I spoke with one of the local NH dealers and they couldn't offer any help, they would only replace the assembly (must not be farmers). Not only do I not want to replace the assembly, the pin hole is accessible to repair without disassembly
Any thought?
Thank you, Jim
Any thought?
Thank you, Jim
