Snapper 3080 drive problem
   / Snapper 3080 drive problem #1
workerian
knoxville, TN
Snapper 3080
Hey all. I have a 70's era Snapper 3080. Ran great for the last two months - as long as I've had it. Now it will not drive in any gear. The clutch mechanism seems to be fine - I can move it into all gears and watch the parts move from underneath, as they should. But when I start it and put it into gear, it doesn't move. This happened suddenly, on the last mow, coming out of reverse. Thinking about opening up the transmission to see what's in there. Any advice/suggestions for a novice before I open her up?
Thanks!
   / Snapper 3080 drive problem #2
You can stand it up on its bumper and try to turn the back wheel by hand if the clutch wheel turns the chains should be ok maybe the disc that comes down from the engine needs adjusted I hope you can understand what I am saying. Could be the short or long shift is loose or broken. I hope it helped and its not a broken chain that's alot of work!
   / Snapper 3080 drive problem #3
Let me know how it goes!!
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
Pallet of Lights (A53117)
Pallet of Lights...
Flat Bed (A52377)
Flat Bed (A52377)
2025 SDLANCH SDLD25 UNUSED Crawler Dumper (A53117)
2025 SDLANCH...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
