NJDiverDan
I just picked up a used old 3 pt snowblower for my BX24. It is an open gearbox chain drive blower. The PTO shaft connects to the blower on a smooth shaft with a keyway. There is a set screw that is supposed to hold the keyway in place.
No matter how tight I make the set screw, the PTO shaft will start to back off the shaft. Most keyed shafts I have dealt with have a cross bolt that holds the shaft on but this one does not. It looks like one of the previous owners tried to drill for a cross bolt, but only dimpled the shaft (got through one side of the yoke). Should I continue to drill this out? Seems like drilling the shaft may not be the best of ideas?? Can I put lock tite on the set screw? Not sure if the set screw is backing out and that is causing the slipping or the slipping is causing the set screw to not be tight, but the set screw is easily turned every time it has slipped.
I am picking up some new keyways today, maybe that will help???
Thank you for any suggestions.
-dan
-dan
