Smoking?????
   / Smoking????? #1
mbohuntr
Platinum Member
Upstate NY
Mahindra 1533
I've got a 4 yr old rider that, since last year, smokes when it first starts. I changed the oil,and filter. Greased er up, put stabilizer in the gas, ran it into the shed, and pulled the battery for the winter. I started it up yesterday, and it smoked heavily for the first 3 or 4 minutes. This machine is maintained, and doesn't have many hours on it???? Any thoughts? There is no smell of gas in the oil...and it stops smoking after a few minutes.
   / Smoking????? #2
does it do it every time you start it? everything i own if it sits for more than a month smokes a few minutes until warm.
   / Smoking?????
Thanks for the quick reply. It started to do it last year. Pretty much every time after it has sat for about a week. kinda like a car that is getting bad valve guides. I haven't played with the newer motors, so I was thinking about that cause (valve leakage OHC???) or a friend suggested horizontal cylinders with ring leakage??? (I tried not to laugh, I have never heard of that, and since it is a newer motor, he might be right, and I'd look pretty stupid,...) I really haven't looked at the motor closely since it was new.
   / Smoking????? #4
... a friend suggested horizontal cylinders with ring leakage??? (I tried not to laugh, I have never heard of that, and since it is a newer motor, he might be right, and I'd look pretty stupid,...) I really haven't looked at the motor closely since it was new.
Your friend is absolutely correct. You didn't state what model rider this is, or the engine make/model, but at a guess it's a newer vertical shaft, OHV Kohler. The cylinder orientation on these engines is such that oil from the sump can easily leak into the combustion chamber. Being even slightly overfull of oil will cause this. Parking them nose-down can cause a cloud on startup as well.
Joel
   / Smoking?????
Boy am I glad I didn't laugh !!!!!! :ashamed: Thank you very much, I'll look into that.
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A50397)
1989 Freightliner...
Mayrath 10 x 31 Truck Auger (A50514)
Mayrath 10 x 31...
E-Z Trail 680 Adjustable Head Cart (A50514)
E-Z Trail 680...
2006 GENIE GTH6622 TELESCOPIC FORKLIFT (A51242)
2006 GENIE GTH6622...
Progressive 36ft Mower (A52128)
Progressive 36ft...
