smoking kioti
   / smoking kioti #1
frank12345
ITS A DIESEL TRACTOR KIOTI LB 2202 U CAN SMELL THE FUEL THE TRACTOR IS RATED @ 2800 RPMS I HAD THE INJECTORS AND PUMP REBUILT ALSO NEW RINGS ROD BEARINGS VALVE STEM SEALS BUT LIKE I SAID WHEN IT WARMS UP TO OPERATING TEMP IT CLEARS AND U ONLY HEAR A MIS OUT OF THE EXAST AND ALSO WHEN FIRST STARTED IF I DROP THE RPMS TO 2500 THE SMOKE CLEARS AND U HEAR A MISES EVERY 3 SECONDS
   / smoking kioti #2
It may not have the rings seated. Hook it to a plow for a few hours or have your dealer put it on the dyno for a while. You could also check to see if they set the pump timing right.
   / smoking kioti
iam sure the the rings are seated and the timing is corect
   / smoking kioti #4
Frank,
It has to be one of those or they messed up the pump.
   / smoking kioti
it was doing it before the overhaul
   / smoking kioti #6
Sounds like there was a manufacture problem with your pump then. A standard rebuild wouldn't correct that.
   / smoking kioti #7
Since a diesel has no ignition, it has to be bad fuel, dirty air cleaner, clogged exhaust, or one of the repairs you mentioned was done improperly. Were any problems found when it was torn down? You mentioned dropping the rpm to 2500 after startup, does that mean you run it full throttle on startup? /forums/images/graemlins/confused.gif
   / smoking kioti #8
</font><font color="blue" class="small">( AND ALSO WHEN FIRST STARTED IF I DROP THE RPMS TO 2500 THE SMOKE CLEARS AND U HEAR A MISES EVERY 3 SECONDS )</font>
with the above quote, are u saying that u start the tractor with the throttle set above 2500rpm?
   / smoking kioti
clean tank out change filters a syndyne treatment put in noting works
   / smoking kioti
can i run it with the muffler off just to see it works i have to set the throttle all the way just to get it started glow plugs work it smokes when cranking
2004 Chevrolet Silverado 2500 Service Truck (A53422)
2004 Chevrolet...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
2005 FORD F450 XL SUPER DUTY DUMP TRUCK (A51406)
2005 FORD F450 XL...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
2006 Utility 3000R 53ft T/A Reefer Trailer (A51694)
2006 Utility 3000R...
