smoking 3TN V82A Yanmar ?
   / smoking 3TN V82A Yanmar ? #1
engmachshop
[/FONT] cust. called said , 1 of their employees some how put [gas in the Diesel fuel tank????] now the engine SMOKEs & can't get #2 cyl. to Fire , they did do Compression Test & they don't understand , How ALL cyl.s have [aprox.] Same Compression Reading ????
this engine 3TNV82A 3cyl. Diesel is in a "997 John Deere Lawn mower"
[sn :MOMZD0304429 .
Any HELP finding out what is causing this engine to Smoke & not fire #2 cyl. Would HELP us to look Better[than we are] & mainly HELP us HELP our customer????
THANK U :confused2:
butch @butch's auto&diesel machine shop
318-787-6049
gasdieselengine@suddenlinkmail.com
   / smoking 3TN V82A Yanmar ? #2
I am no diesel tech but on a misfire on my engine I would pop test the injector(s) first and go from there #2 may very well be stuck open, it has to have correct amount of fuel as well as compression yes? hth
   / smoking 3TN V82A Yanmar ? #3
Not much info there. Did they try to run on gas? What was done to remedy situation? Were fuel lines bled correctly? How do they know #2 is not firing?
   / smoking 3TN V82A Yanmar ? #4
Compression good on all cylinders but #2 won't fire?
Maybe swap the injectors around and see if the misfire follows the #2 injector.
   / smoking 3TN V82A Yanmar ? #5
I'd have the injectors pop tested. I doubt that is the problem. How long was it run? Diesel fuel lubricates the injector pump. Gas will not lubricate it.
   / smoking 3TN V82A Yanmar ? #6
Neighbor borrowed my brothers Massey 35 with a 3 cylinder Perkins and filled the diesel tank up with gasoline and they ran it till it quit.The injector pump had to be rebuilt. Other than that it was OK.
2006 Peterbilt 335 Day Cab Truck (A53117)
2006 Peterbilt 335...
2015 Ford F450 Flatbed Truck (A52377)
2015 Ford F450...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
