Smokey 5103
   / Smokey 5103 #1
deerefan
Veteran Member
louisiana
1952 8N, 2005 JD 5103
I cranked my tractor after it sat for a few days and it billowed white smoke, ran rough (barely ran), cleared out after a few seconds and I idled it up. After about 10-15 seconds it ran fine. Is this common? It did stay rather cold here a few days and from past experiences with diesel generators I think this is normal. After a short warm up, the tractor ran fine. I guess I am asking if this is normal, just a little skeptical b/c the tractor only has 25 hrs and is about 4 months old. Thanks for the input.
   / Smokey 5103 #2
I don't think it is of concern while you experience colder temps. That model doesn't come with any factory pre-heater or block heater, unless installed by the dealer. These new engines are acting different in a lot of ways, due to the design to meet emission requirements. Ask somebody with the large frame compacts, 4120 up thro the 4720, and they will tell you that these are nothing like the old yanmar engines in the 4510-4710 tractors.
/forums/images/graemlins/cool.gif
   / Smokey 5103 #3
The smoke is from incomplete combustion, my 990 does the same thing I just let it warm up for a few minutes before I take off and get to work.
   / Smokey 5103 #4
I can get smoke too (with the Yanmar diesel) if I don't hit the glow plugs long enough, or if the previous time I ran the tractor I didn't get it good and warm before shutting it down.
As long as it clears up after warming up, I would treat it as a normal condition. The incomplete combustion comment was right on.
Appreciated hearing about the comment from Dutch. I think many of our engine experiences are changing based on the excitement from the EPA and the regs they hand down. Once such an organization exists, it will continue to come up with new restrictions just to justify their existence, if for nothing else. Happens with all govt. agencies.
   / Smokey 5103 #5
Yep, some white smoke is normal as the temps drop. I think that's an EPA Tier 2 engine, which is the newest requirements. Nothing to worry about.
   / Smokey 5103 #6
My 5203 does the same thing--cold natured beast. But after a bit it smooths out. /forums/images/graemlins/smile.gif
   / Smokey 5103 #7
Hi,
That 5203 is a good machine! I generally try to park my tractor in the barn when it's callin for cold.
   / Smokey 5103 #8
My brother's 5103 does the same thing. It is normal. Most diesels will billow white smoke on startup if they are cold. Make sure you are in a well ventilated area.
   / Smokey 5103 #9
is it normal to do when it's 75 degrees outside and have not been used in a week?
   / Smokey 5103 #10
You can loosen the injection pump, turn it slightly clockwise, and retighten. Advances the timing and white smoke should clear right up. Not a rare problem with 5003 series tractors. Happened on about 20-30% of the 5003's we sold.
Mark the pump and housing before loosening any bolts and you'll have a "reset" in case you turn it too far.
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
TAKEUCHI TB250-2 EXCAVATOR (A52705)
TAKEUCHI TB250-2...
2003 Pierce Spartan Pumper Fire Truck (A54814)
2003 Pierce...
UNUSED LANDHONOR LHR-BLC9021 TOOL STOOL (A54757)
UNUSED LANDHONOR...
UNUSED RAYTREE RMA42 HYD AUGER (A54757)
UNUSED RAYTREE...
