Smoke From 1020
   / Smoke From 1020 #1
Bocephus2002
North Carolina
Massey Ferguson 1020 Standard
I recently purchased a MF 1020 standard for dirt cheap. Everything seems to run ok but the engine blows a light blue smoke out of the exhaust and from a tube coming from the valve cover. Is the tube some type of breather for the crankcase? I was thinking the rings were starting to go causing to much pressure in the crankcase. Just wondering if this is something I should worry about.
I also have a MF 146 (I think is the model) FEL that I am wanting to mount. Does anyone know where to purchase the bracket kit? And roughly how i would hook up the hydraulics? Any help would be great.
Thanks,
Mike
   / Smoke From 1020 #2
You don't indicate how many hours on the engine, so it would just be a guess but sounds like you may have some worn rings. I think you correctly identified the breather tube. Both the 1010 and 1020 have them according to my manual. I'm not a mechanic, but blue smoke is not normal. Some diesels smoke like that at start up, but if it's continuous, that's an indication of some wear. I'd just run it if I were you. I think you can still buy overhaul kits for them. I know you can get them for the 1010.
   / Smoke From 1020
I think it is my rings and the blue smoke is coming from the blowby. Hopefully I can locate the parts to rebuild.
Electric Mobility Scooter (A51694)
Electric Mobility...
2013 Nissan Pathfinder SV SUV (A50324)
2013 Nissan...
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A52748)
FIRESTONE 9.5L-15...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2014 Kia Sorento SUV (A50324)
2014 Kia Sorento...
1993 Ford F700 Stakebody Truck (A51692)
1993 Ford F700...
