Smith torch o rings
   / Smith torch o rings #1
big bubba
Elite Member
arkansas
M8540
apologize in advance for such a simple question. had my Smith torches/welding tips since early 70's. never a problem. the o rings are original &
am careful in making the various attachment connections. my question is what is the recommended "lube" to prevent tearing, etc to the rings.
remembered when i learned, not to use petroleum based products/oils with an acetylene system for safety reasons (flammable).
your thoughts? Probably should get a replacement kit from Smiths anyway. thanks in advance
   / Smith torch o rings #2
perfect
the 2nd link was what i was looking for.
so far, regulators in good shape... thanks
   / Smith torch o rings #4
I’m following this with interest. The o ring material from the 1970s was different stuff. Not impervious to almost all chemicals like the stuff today. Let us know how it goes if you do decide to add something to those old seals.
   / Smith torch o rings #6
Smith O-rings come with a thin grey graphite looking lube on them. When it wears off from changing tips they want you to replace them. For the other brands you can get a small tub of o-ring grease for automated plasma o-rings. Usually free and will last for ever. Remember, Less is more when greasing o-rings.
   / Smith torch o rings #7
No lube allowed on any oxygen fittings. Other than that, there exists actual "o-ring" lube sold by the nice people at Parker Hannifin. Probably can find a tiny tube of it on ebay or just searching online.
   / Smith torch o rings #8
thanks for the responses on my o ring lube question. am ordering lube & set of replacement Smith's o rings from Reg & Torch Replacement Co as recommended by DL Meisen
only use the torches a few times yearly. to be honest, the current o rings on the torches & welding tips are from my original purchase in '71.
guess it's time to replace. fortunately no damaged rings, but prob a good idea to replace. (i take good care of them :)
Smith torches are the most reliable ones i've run across. quality equip pays for itself over the years....
thanks again
   / Smith torch o rings #10
Many materials spontaneously combust in the presence of pure oxygen. Any grease that isn't certified to be oxygen safe is really likely to do so.
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A51039)
Ditch Witch 6510A...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
1997 INTERNATIONAL 8100 4X2 WATER TRUCK (A50458)
1997 INTERNATIONAL...
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
