SmartStraps Tie Downs
   / SmartStraps Tie Downs #1
Lutzy48
Miles City, MT
Ford 1710
Anybody have any experience with SmartStraps tie-downs. I had bought some ratcheting tie-downs at Home Depot and had to return them as they were chafed after one use. And no it was not a sharp edge that did it. It was a radiused corner square tube. If you know of a better brand of decent tie-down, recommendations would be appreciated. I don't want to loose my 4000# + Ford tractor.
   / SmartStraps Tie Downs #2
Chains don't get chafed.
That said though, I use mostly straps as well. I can't really recommend one brand over the other though. Check ou US cargo control. That is probably where I will buy my next ones.
   / SmartStraps Tie Downs #3
I like the Erickson straps. They seem to last and replacement straps are pretty cheap.
Nothing will take sharp edges without some sort of protection. Chains are better overall, but harder to work with.
   / SmartStraps Tie Downs #4
Old split fire hose makes good chafing protectors!
   / SmartStraps Tie Downs #5
Chains are your answer.
I don't use straps for anything that has wheels or tracks.
Straps are good for some things but I prefer chains on vehicles.
   / SmartStraps Tie Downs #7
   / SmartStraps Tie Downs #8
Check with you local fire station, fire hose must be tested yearly, they may have some old hose available. We usually just cut the couplers off & tossed the hose in the dumpster.
   / SmartStraps Tie Downs #9
I use straps 90% of the time. The key is to not allow the strap to touch the equipment. I installed permeant tie down points on my equipment so the hooks of the straps are the only thing that touches.
For hauling stuff that's not mine I have 4 axle straps and 4 towing multi hooks.
Chris
   / SmartStraps Tie Downs #10
Lutzy48 I have a 1710. I run a 5/16 chain in the front through the little piece the suitcase weights would hang from. Then I run another 5/16 chain through the pin in the drawbar. Straps are not usually dependable enough for tractor use, and I would not trust them. They do work great for garden tractors though.
NEW Fork Extensions (A53002)
NEW Fork...
ITEM LOCATION (A53084)
2020 TAKEUCHI TL 12V-2 (A52472)
2020 TAKEUCHI TL...
2014 PETERBILT 386(INOPERABLE) (A52472)
2014 PETERBILT...
2024 Bintelli ActivEV Pulse Electric Golf Cart (A51694)
2024 Bintelli...
