Backhoe Smallest tractor for a Bush hog 950 backhoe?
   / Smallest tractor for a Bush hog 950 backhoe? #1
HuskerInVA
Loudoun County VA
JD 3520, '71 Case 580CK TLB
I know the manual states recommended HP range of 55 to 100 for the Bush hog 950 backhoe, but I was wondering based on real world experience from folks what the smallest tractor that has been successfully used with this hoe? I would think weight/frame size of tractor would make a bigger difference than HP as long as you have the hydraulic flow to power the hoe.
   / Smallest tractor for a Bush hog 950 backhoe? #2
I have a BH 750 on a NH TC30. Even with loaded tires it can still move it around quite handily. I would think with the 950 you'd want a heavy tractor.
Mine is hooked to the tractor hydraulics and it works just fine running at 1200 rpm's. Especially at my skill level. /forums/images/graemlins/wink.gif Don't forget about transporting the hoe. I don't know the specs on the 950 but I bet it's heavy. You're going to need some tractor weight to move it.
Hopefully some one with a 950 will chime in.
Rodger
   / Smallest tractor for a Bush hog 950 backhoe? #3
I've got a Woods 9000 on a Ford 2120 (40hp). I guess the Bush hog is a 9 and a half foot digging depth. The rear tractor casting will see some tremendous forces even when using a sub frame. I can lift my front end by hooking the bucket under a stump. The tractor and BH weight #7600 so I can't imagine an even larger BH on a smaller tractor. Why such a large hoe?
A few miles from me there's a 950 sitting at the end of a driveway with a for sale sign on it. I haven't called to ask how much yet, but I am pretty sure it's too big for my JD 3520 anyway. But, if someone comes back and tells me they're running the large hoe on a midframe tractor -- I would be at least tempted to find out how much they are asking.
40' CONTAINER (A51244)
2019 Chevrolet Cruze Sedan (A50324)
2019 Chevrolet...
Farmall 460 Tractor (A50514)
Farmall 460...
Skid Pro Quick Attach Plow (A50514)
Skid Pro Quick...
Spool of Wire (A47384)
