Smaller 3 point spreader for sand, maybe salt? Other recommendation?
   / Smaller 3 point spreader for sand, maybe salt? Other recommendation? #1
Timmer92
Bronze Member
Minnesota
Kubota L3901
Hi all,
I have a very large 3 point broadcast spreader that we use for our fields. I'm looking for a much smaller and less expensive unit for putting sand, and maybe salt, on our driveway. Anyone have any recommendations?
Thanks!
   / Smaller 3 point spreader for sand, maybe salt? Other recommendation? #2
I usually just take a 5 gallon bucket out and scoot it along and throw from the bucket by hand.
The fertilizer push spreaders would probably work for sand and some salt (if in hard crystals). I've also a little hand spreader, but it doesn't hold much.
Your field spreader would be safer, as you would not be out there on slick surfaces on foot. Not sure how far down you can crank those things. Could spread 5 gallon's worth pretty quickly.
Ralph
   / Smaller 3 point spreader for sand, maybe salt? Other recommendation? #3
I have a blower on the back so no way it is coming off for a spreader...I HATE connecting PTO's.
I think Ralph has a good idea for addressing a larger area. I have a small push type and a larger pull one that hooks up to my riding lawnmower. If there is enough friction to rotate the wheels of the spreader, they should work. If not, getting solid tires and driving some sheet metal screws into the tires might do the trick. I think I paid about $40 for the push one and $250 for the larger pull one.
I only salt the pad in front of the garage so I hand spread.
   / Smaller 3 point spreader for sand, maybe salt? Other recommendation? #4
Typical seed/fertilizer spreaders like Scott's from Home Depot and such do not work for sand in winter. Been there, done that.
2014 FREIGHTLINER M2 DAY CAB (A51222)
2014 FREIGHTLINER...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2015 FREIGHTLINER  CASCADIA (INOPERABLE) (A50854)
2015 FREIGHTLINER...
John Deere Gator XUV835M 4x4 Utility Cart (A48082)
John Deere Gator...
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2011 TROXELL...
2014 PETERSON 4700B HORIZONTAL GRINDER (A51242)
2014 PETERSON...
