Small Trenching Bucket fro gc2319 BH
   / Small Trenching Bucket fro gc2319 BH #1
spudware007
SE Michigan
MF GC2310TLB
I have a 2310 and I amy looking to make the narrowest trench I can for a french drian in the bottom of my ditch in the front yard. What are my options?
   / Small Trenching Bucket fro gc2319 BH #2
If you have clay soil you have no options, a narrow bucket will tend to pack tight and require you to manually remove the dirt after almost every bite.
I was warned about this before I built my 6" bucket but, I invested the time and resources only to find out they were all right.
A veteran excavator will usually not want to use a bucket smaller than 12" because of this phenomenon.
When I really want a narrow trench I have to rent a trencher. Not cheap but, really fast. Not going to help you though.
   / Small Trenching Bucket fro gc2319 BH #3
Try welding a section of 5/16" or 3/8" chain to the top inside of the bucket about 18-24" long (just short enough that it won't stick out past the teeth). It will help break the suction of the clay so that it can fall out of the bucket.
   / Small Trenching Bucket fro gc2319 BH #4
Thanks Jerry, I have been told to try that. I bought the chain in 6 months ago and have not had time to try it. I have to say I am skeptical of it working since every thing else did not, (i.e. dual taper shape, air holes, various lubricants, coatings). If I can, I will try it this weekend and report back.
   / Small Trenching Bucket fro gc2319 BH #5
Tried the chain, its too dry around here right now. I could not find a wet enough area to test it properly. Stay tuned.
   / Small Trenching Bucket fro gc2319 BH #6
Good post I hadn't thought about this issue. I get enough sticking with a 16" bucket..... I have not used my 9" yet... but was planning on it in a couple of weeks......... maybe I'll stick with the 16.
thanks
2021 Doosan DX350LC-5 Hydraulic Excavator (A50322)
2021 Doosan...
Wolverine Quick Attach Stump Grinder (A50515)
Wolverine Quick...
2013 Mack GU713 T/A Vac-Con Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
Case SC Tractor (AS IS) (A50774)
Case SC Tractor...
2009 CASE IH3406 - 6R36" CORN HEAD (A51243)
2009 CASE IH3406 -...
Loader with IH Brackets (A50515)
Loader with IH...
