Small tractors doing big work.
   / Small tractors doing big work. #1
VroomVroom
Platinum Member
Newfoundland
Mahindra 2816 HST, Super M farmall, J5 bombardier, 230 timber jack skidder
Just wanted to open a little thread of sorts. I was always impressed while searching the net of all these really small tractors doing heavy work, or being worked hard over the years. Some of those videos in eastern Europe showing the guys with their little tractors are impressive. Some of those videos of the B6000, B7100's, or those little B1620 Kubota's just to name a few. Or some of those lesser know makes that are used to their full potential. Especially when the guys have all the attachments for them. Using the tractor plus the power source (pto) to perform work. Anyone got any pics, post them here. I'm talking maybe 25 hp or less.
   / Small tractors doing big work. #2
No pictures, but I had a neighbor who ran a 5 foot JD tiller with a little L185 Kubota; and wore the tines right off from it. The tractor had a 3 speed PTO which probably helped, but still, it was only a 15HP tractor.
   / Small tractors doing big work. #3
It mainly depends on the job you need done and the time you have to do it. I filled 10 acres that was a harvested corn field. Turned it into horse pasture. 25 hp tractor and 5 foot tiller.
Of course a bigger hp tractor would have gotten it done faster. But I used what money I had to buy the tiller and took my time with it.
Also have moved many many cubic yards of dirt. Again took my time with it.
Now that all the 澱ig jobs are (mainly) done the 25 hp tractor fits the bill. I am sure there will be future jobs where I have to get creative to get it done with 登nly 25 hp.
   / Small tractors doing big work. #4
Does this count as hard work? :D
This was my Kubota B7000 pulling a 28 hp crawler tractor. The combined weight with tractor, mower and trailer was around 4500 lbs.
I don't own any of these anymore.
Yes, that counts. I think the small tractor thing is because of a tendency to root for the underdog. Some of them poor little things just keep working after straining under large tasks. How was the little 7000?
   / Small tractors doing big work. #6
Here is my little LS mt125 TLB putting in a septic system, then setting fence posts using the PHD. I have done a bunch of trenches, grading, and spreading stone. Great little Swiss Army knife!
   / Small tractors doing big work. #7
These little machines are really tough. I've owned that Kubota for around 20 years, bought it used. I've only changed one rear axle seal, dynamo bearings, one battery, fan belt and a clutch were the pressure plate finger had worn out. The clutch disk was still fine.
Oh and had to get the pivot pin for the front axle made because the previous owner didn't really care at all about adjusting the nut in the end to remove the play.
I have built the loader for this tractor. And also built an hydraulic broom. Worked really well. Here is a video:
What is the difference of the 7000 to say the current bx25's I see around?
   / Small tractors doing big work. #9
Sizewise I think it's more comparable to a B series than the BX, which I think it's a bit smaller, but I've never seen it side by side. I might be wrong.
Other than that, you get all the good stuff that make the operator more comfortable and more user friendly, like power steering, live PTO, all the eletronic stuff, suspension seat, synchronized gears in the gear model, hydrostat model, higher flow hydraulics and easier to add valves, quick attach loader, backhoes, etc.
A true 3 point hitch, that the B7000 doesn't even have unless you get the 3 point kit. These were made to be used with a rototiller that uses a proprietary attach system.
The list goes on and on. It's all I remember at the moment.
   / Small tractors doing big work. #10
I have aleways owned larger tractors, but for many years my little ford 1620 was the go to winter snow removal tool. It is matched to a 62 inch snow blower that does not know the meaning of CAN'T. Still use this tractor in tight spaces and a 5 ft woods M5 makes it ideal for trail maintenance through the woods. LS MT125 offered a compelling counterpoint to a poster that insisted any tractor weighing less that 3800 lbs was or is a waste of time and money. That "tractor guide" fellow can not be further detatched from the actual truth.
Underestimate the smaller tractors at your own peril, you provide the time, the tractor will deliver the determination.
2024 Case IH Magnum 340AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
2014 Ford F-550 11ft Godwin Mason Dump Truck (A48081)
2014 Ford F-550...
Unused 2025 40ft. Texas Pride FT835524KGN 13 Ton T/A Gooseneck Flatbed Trailer (A49346)
Unused 2025 40ft...
2020 JOHN DEERE 332G (A50854)
2020 JOHN DEERE...
2011 Peterbilt 386 Sleeper Truck Tractor (A50860)
2011 Peterbilt 386...
2008 Ford F-250 Reading Service Truck (A48081)
2008 Ford F-250...
