Small trackhoe to compliment my CUT?
   / Small trackhoe to compliment my CUT? #1
Diamondback
Bronze Member
Mountains of NC
Kubota Grand L4060
Great site. Have spent many hours pouring over the vast information here.
I have a Kubota L35 TLB and love it but my property is mostly 20-30% grade and heavily wooded. After watching a bobcat 331 work an area in a fraction of the time it would have taken me to clear I have considered buying a small trachoe to take on the tasks better suited to a track machine.
Since we are currently building a house a smaller, used machine is all the current budget will allow. My neighbor has a bobcat 322 he wants to sell. Haven't seen the machine yet but after looking over the specs it appears to be a bit small (19hp, 3500 lb machine) to truly be a compliment to my Kubota. It is, however, in my price range. Just don't want to put that kind of money into machine that lists lifting capacity with blade down at just a little over 500 lbs.
Anyone out there familiar with the 322 or that size trackhoe in general. Any thoughts or suggestions would be appreciated.
Thanks, Diamondback
   / Small trackhoe to compliment my CUT? #2
   / Small trackhoe to compliment my CUT? #3
I was in the same situation. I had an L3010 with a BH, but needed something bigger with a longer reach. So I traded up to an L4630 intending to get a larger BH to go with it. But then a friend let me use his Kubota KX-71 mini excavator and it was SO much better than any backhoe I was hooked!
The 71 was a bit small for my needs, so I started shopping around. Did a lot of research, talked to a lot of equipment mechanics for the brands that had support in my area: Bobcat, Cat, Volvo and Kubota. The local mechanics said Bobcat had some issues. Minor issues, but not trouble-free. That was confirmed by the owners I talked to, all of whom loved their machines but expressed some annoyance at times. The other three were rock solid and expensive! In the end I went with the best used value I could find -- a Kubota KX121-3 with two buckets and an angled blade with float.
I absolutely love the machine! For harvesting boulders or firewood, clearing ditches, sculpting the land a mini-ex just can't be beat! But I'd advise against going too small. Get one that meets your needs, even if you have to wait a bit.
   / Small trackhoe to compliment my CUT? #4
I have a Bobcat 322. It has paid for itself . I use it in the city for very tight spots. I have controls set the same as a big excavator so its easy to move to a bigger machine. There are some nasty mini accidents on You Tube.
2011 MACK CHU (PINNACLE) (A53843)
2011 MACK CHU...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
2018 JLG G9-43A (A47477)
2018 JLG G9-43A...
TOTE OF CONCENTRATED METAL CLEANER WITH HOSE AND DIAPHRAM PUMP (A53843)
TOTE OF...
2018 Freightliner M2 106 Altec LR756 Forestry Bucket Truck (A52377)
2018 Freightliner...
