Small Time
   / Small Time #1
myjohndeere2022
4400 JD
Hi everyone ! Having an issue with my 4400 with a 430 loader on it , the loader doesn’t have any lift pressure up or down neither does the bucket , it seem to happen all of a sudden , it will go up and down but can’t lift anything , hydraulic level is good , any thoughts where I should start? Thanks
   / Small Time #2
Has it ever worked properly? Start by making sure your three point control is not on the full lift position. If it's not adjusted properly that can cause loader slow down and lift weakness.
   / Small Time #3
Usually there is a "3 point hitch control valve" located just behind your feet, under the seat. I've had that get urned by moving my foot around and it essentially shuts down the hydraulics.
   / Small Time #4
That valve only controls flow to the 3 point..... won't have any affect on the loader. Unless the flow is totally reversed... which is probably not even possible
   / Small Time #6
Is the hydraulic reservoir full? Also, check the filters. Nice tractor when you get it running right. Gas or diesel?
2017 Kubota M5-111D 105HP Agricultural Tractor (A52377)
2017 Kubota...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
Bomag BW 211D-3 (A47477)
Bomag BW 211D-3...
2022 FREIGHTLINER CASCADIA SLEEPER (A54607)
2022 FREIGHTLINER...
PAIR OF UNUSED 60" HANG ON FORKS (A54757)
PAIR OF UNUSED 60"...
40' CONTAINER (A51244)
