Small propane heater problem.
   / Small propane heater problem. #1
Fuddyduddy1952
Super Member
john deere
I'm trying to work in a small insulated shed and I use this 15,000 btu propane heater. It probably has 50 hours use total. I make sure all connections tight, propane on, set dial, press/hold pilot valve & light. Release pilot valve after 30 seconds or so.
It runs normally for a couple minutes then sounds like a jet engine & flames shooting out! I quickly turn gas off. I've tried it twice, same thing. I'm guessing it has a pressure regulator that's malfunctioning.
I assume just replacement is necessary unless someone has an idea what's wrong?
   / Small propane heater problem. #4
Glad to hear it's ok. I was about to say check tube between orifice and burner for spider web or other seemingly insignificant bit of trash.
206320 (A57192)
206320 (A57192)
2021 XCMG CV123PDU ROLLER (A60429)
2021 XCMG CV123PDU...
2012 CATERPILLAR 308D CR EXCAVATOR (A59823)
2012 CATERPILLAR...
2011 DRAGON 130BBL VAC TRAILER (A58214)
2011 DRAGON 130BBL...
207269 (A52708)
207269 (A52708)
2012 Ford E-250 Cargo Van (A59230)
2012 Ford E-250...
