Small Hydro Leak
   / Small Hydro Leak #1
fenneran
Staunton, VA
Kubota L2900
I have a YMG1800D, which must be pretty rare since I have't seen anyone else with one, that has a small leak in one of the hydrolic lines. It only seems to drip a little, and only when there is a lot or pressure on it. For instance, when the three-point arms are lifted to the top.
This is a shot showing the line that has the leak:
This is a closeup of the actual joint that's leaking. (sorry for the dirt, I haven't cleaned ut up yet /forums/images/graemlins/frown.gif )
So, now for the questions:
1. Is this fairly simple to fix?
2. Do I need to worry about breaking that joint (for instance, does getting air in the line cause a problem?)
3. If so, what precautions do I need to make?
4. Where do I put more hydrolic fluid to replace what will leak out while I'm fixing it?
Thanks in advance.
-Frank
   / Small Hydro Leak #2
Copper washers?? Not model spacific - but similar problem. Used very fine (400/600) abrasive lapped on a hard, flat surface. gently removed imperfections and cleaned all (3)machined mating surfaces too. Simple, really. Stop the leak under heavy load and no bleeding was necessary.
I am not sure of your model. Good luck, Mark
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2019 Caterpillar 950M Articulated Wheel Loader (A51691)
2019 Caterpillar...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
Electric Mobility Scooter (A51694)
Electric Mobility...
UNUSED FUTURE CG34 - 34" HYD CLAMP GRABBER (A51248)
UNUSED FUTURE CG34...
