Small Hydraulic leak on 3520
   / Small Hydraulic leak on 3520 #1
BigMike50
Uranus
2012 JD 3520 Cab 1996 JD LX172 1985 Wheel Horse
this unit mounted on the side of the engine is leaking somewhere by both line outlets underneath. Not really dripping but it is all wet with debri sticking to it. anyone else notice such an issue? machine has less than 150 hrs. any thoughts? only noticed it because I was laying under machine inspecting undercarriage for things like this
   / Small Hydraulic leak on 3520 #2
That's one of two hydraulic pumps for your tractor. They're facing each other. I forget... if the main implement pump is closest to the cab or if the power steering/auxiliary hyd pump is the one that's closest to the cab. Either way; it's one or the other!
It's a compression fitting and it may just need to be snugged up a bit. The technical repair manual has the torque specs to tighten it. Or... since it's under warranty - your dealer might be able to provide that (and a torque wrench - loaner).
AKfish
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A54814)
2012 Crane Carrier...
JMR tree boom attachment (A53421)
JMR tree boom...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A53473)
NEW 2024 LOAD...
UNUSED PE Industrial Stretch Wrap Rolls (A53117)
UNUSED PE...
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
2009 KENWORTH T6 SERIES SLEEPER (A53426)
2009 KENWORTH T6...
