Small hydraulic leak in new loader arm
   / Small hydraulic leak in new loader arm #1
spunky
ky
2320 JD
My 2320 has only ten hours and the 200CX loader is great! However, I noticed a small amount of hydraulic fluid under the right arm of the loader. The leak appeared to originate near a fitting which was tight and not actively leaking when I re-started the tractor. I had put the loader to the test the day before by moving a large piece of concrete for my neighbor. The dealer says that sometimes a seal just doesn't seat properly and this could be the case and they will fix if it persists. It has not leaked since. Is the dealer's explanation possible? Why isn't it now leaking?
   / Small hydraulic leak in new loader arm #2
It may need to wear in ot 'seat'.
My b2150 with a dual loader would, since day 1, slowly drop or lower with the engine off.
Last year with 900+ hrs, I switched the fluid to Schaeffers hyd. and it now stay put !!!!!!
Great hydraulic fluid.
Hydraulic 50 mm pin thumb (A52384)
Hydraulic 50 mm...
10' WROUGHT IRON SITE FENCE (A51248)
10' WROUGHT IRON...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
(3) STEEL CARTS W/ WHEELS (A51248)
(3) STEEL CARTS W/...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A51248)
UNUSED WOLVERINE...
