Small Goat Barn Question
   / Small Goat Barn Question #1
jhendric
Bronze Member
Holly Springs, NC
none
Folks, I've read many of the threads on building a goat house and I still have a question. Many of the you tube videos I've watched have just a dirt floor under a pole barn for goats. Is there any advantage of having concrete or some other raised floor? I am concerned that urine will build up over the years. This will be for Nigerian Dwarf goats. Any other advice or lessons you have learned will be appreciated too. These goats will be for, well, basically pets and for clearing up invasive ground vegetation.
My shed will be 8x16 7' high pole barn with half being open and covered and half being enclosed.
   / Small Goat Barn Question #2
Sorry, I don’t have any feedback for you. Subscribing to this. Something I pondered at one point in time to control some poison ivy. Curious how much maintenance the little guys are. Growing up we had everything but goats.
   / Small Goat Barn Question #3
We use a shed for our goats that was previously used for something else. It has a concrete floor. I personally think it is useful, but you still need to muck it out regularly. A good 'grain' scoop works well. We use TSCo shavings as bedding, and you can also first put down Stall Dry, an absorbent and deodorizer. A little of that goes a long way. In another goat house with a wooden floor (a very small one where we keep new goats) I put down old sheets of plywood over the wood flooring to protect it a bit.
Understood about the regular mucking. I'm curious about the wood floor. Did it rot out quickly?
   / Small Goat Barn Question #5
Just how small are your goats ?
Well, they are still in their mother's womb at this point. They should stand no taller than 20" and we intend to have 3.
   / Small Goat Barn Question #7
No, it really never had a chance to do that as I put in a sheet of plywood and then shavings. But, it clearly would have rotted out at some point if I had just left it alone. So wood flooring not a good idea unless you have another wood layer you can lay in there to protect the floor. I have once thought about those horse stall rubber mats they sell at TSCo but have not tried it yet.
   / Small Goat Barn Question #8
We used manufactured sand, limestone, on top of dirt in the miking barn. Kept the bedding dry. Some was lost from cleaning and replaced 5-10 years. Helped with odor and foot problems. Another barn had a sloped rough concrete. Self cleaning out the back. Rough concrete helped keep the hoofs trim. Goat hoof maintenance is not a pleasant task and they don’t like it either. Handy to grab buckets of compost for planting. Liked that arrangement better. Raised dairy and meat goats.
Goats like to climb. Love rocks and boulders. Built them a tree house. Big crooked tree trunk with steps notched for steps. Hardwood solid top pallets for floors. They would play and felt safe up in the tree house.
   / Small Goat Barn Question #9
The dirt floor will be fine for them. Living in NC as you do, you probably don't have extreme cold weather so bedding won't be necessary. If your Nigerians are like my Boers, they will sleep outside 90% of the time. The shelter will be used during rain or during heavy winds. It would be advisable to put a bench inside the shed so they can get up off the ground too. This is a link to our website about the subject. Shelter It may or may not be helpful. You are doing the right thing to ask questions before putting animals on the ground. We have been raising goats for over twenty years and still learn something new every day.
   / Small Goat Barn Question #10
I'm fairly new to goats, and I still have a lot to learn. I currently have 9 female and one male. Originally they where in one of my two horse stalls. The horses all prefer the other stall, and the goats had that other stall all to themselves. But for whatever reason, the goats started staying on the same side as the horses. I think it was to steel their food, but who knows what a goat is thinking? Eventually we turned that stall into another chicken coop.
My current plan is to build a goat barn off of the horse barn. It will be 36x36 with a dirt floor and walls on all four sides. I will have large doors on two sides so I can control the horses from going in there and steeling all the goats food. It will have stalls so I can separate them when they have babies. I already have a small shelter for my pig that passed away last year, and that will become a separate area for my male goat when I want to keep him away from the others. The main thing for me will be a way to feed all of them in one covered area, and to be able to deal with babies. Feeding in the cold, and dealing with mud and thunder storms has gotten old really fast!!!
For your needs, I would start out with a loafing shed type building with three solid walls and a roof. If it gets really cold there, I might enclose half of the front wall too.
I have not noticed any urine build up. I haven't noticed any goat urine at all. I don't know if the pee inside the horse stall or not, it's just not an issue. When we have had babies, we put out a thick layer of hay for them. Otherwise, dirt is natural for them to sleep on.
Where will you store your feed for them? How you you feed them? They are crazy at feed time. The tend to run from feeder to feeder, constantly steeling from each other. I have five feeders for 10 goats, and that's worked out well. Before, I just spread it on the ground for the, but I like putting it in the feeders better. They also need fresh, clean water. Last week when we froze all week, I had to carry water to them in a five gallon bucket. That was for the horses and chickens too. I need a better way to deal with freezing temps and water. When it's cold out, that's the wrong time to fix it, and when it's nice out, I get caught up in doing other things. It's my own fault, I just need to get a water line that wont freeze in winter!!!
I have a feed room that is 12x12 that is sealed up well enough that I've never found a mouse dropping inside that room, even though I have lots of mice out in the chicken coops steeling their food. I buy feed once a week and it's important to have a dry place to store it and also to be able to scoop it out of the sack and feed the animals.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2010 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A53426)
2010 PETERBILT 387...
Case TR270 Skid Steer (A52384)
Case TR270 Skid...
2019 Bobcat E32i Mini Excavator (A51691)
2019 Bobcat E32i...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
John Deere 4650 Tractor (A53117)
John Deere 4650...
