Small gas-powered water pumps
   / Small gas-powered water pumps #1
Boondox
Elite Member
Craftsbury Common, Vermont
Deere 4044R cab, Kubota KX-121-3S
I need something small, light and hand-portable that I can carry in the forest to jump start 1 inch water lines in early spring (blast out the critters and crud that partially plug them), and would allow me to take suction from my ponds to either water the area around it or hose off the muck from my excavator without bringing it all home where the dogs will track it into the house.
I was considering one of the little Tanaka or Mitsubishi units because they're 2-stroke and as simple as they come, but Honda has a couple of 4-strokes on the market as well. The 4 stroke seems like a no-brainer for reliability, but the two reviews on Epinions.com completely pan the Hondas.
In the world of mini pumps coming in at less than 20 pounds, what's a good pick? (Electric pumps are not an option as the pump would be used up to half a mile from the nearest power source.)
Pete
   / Small gas-powered water pumps #2
Pete
I have had the little four stroke Honda for about five years, the WX 15 I believe. It has been trouble free and very dependable. I water the garden and new grass with it. I throw the suction line in the pond and go do something else, in about an hour it runs out of gas. Then I switch the sprinklers to a new location and check the oil, refuel and let it run another hour. It can handle two sprinklers with ease, three alright but four pushes the limit of that little pump. I don't know who was panning it but I suspect that they had no experience with it.
   / Small gas-powered water pumps #3
I have a Robin Subaru pump. It's 4 cycle, like the Honda and about half the cost. See Subaru Robin | Pump Details | PKV101 for pump info. Starts easily, runs well. Need some PVC fittings to be able to hook it up to a garden hose. Need a corrugated suction hose to draw with; if you try to use a garden hose it will collapse the hose. Places like Northern sell the suction hoses at high prices; I got mine at a pump supply place for about $10.
The pump portion on most of these small pumps are pretty similar in design and construction and it is the engine that is different.
   / Small gas-powered water pumps #4
I've got a little 2 cycle Mitsubishi that I got at Northern Tool. I've had it for a couple of years and use it every couple of weeks. It's been very reliable.
   / Small gas-powered water pumps #5
Pete
You want simple, reliable, easy, go with the little Honda.
   / Small gas-powered water pumps #6
I have three of the small 4 stroke honda's and have not had a single problem with any of them. I use them for fire suppression at the farm. (burn pile got a little out of control a few years ago). When I am burning I have two portable tanks (275 gallon each) and each tank uses one of these pumps ( kind of a redneck firetruck). I put the third at the pond just in case I need to refill either of my homemade firetrucks.
Hope this helps
Greg Bynum
   / Small gas-powered water pumps #7
It is pretty tough to beat a Honda. No matter who I know that has one has had good luck with them.
murph
   / Small gas-powered water pumps #8
you talking about one of these little gems?
   / Small gas-powered water pumps #9
I've been using a Honda WX-10 now for over 5 years to spray chemicals from mix tanks, water my garden, and wash my tractor. It is super reliable and I wouldn't trade it for any other. The pump seal is finally starting to leak, but I would estimate I have close to 200 hours on the little guy. That's a long time to run a small gas pump.
I have used a small Homelite 2-stroke, and it was o.k., but not great.
The honda has the ability to adjust the throttle, which is a nice feature to control output. Whatever you get, make sure it has a throttle.
   / Small gas-powered water pumps #10
My vote is for Honda. Also have a Honda Generator, 4-Wheeler and SUV (Pilot). I like their quality, performance and reliability.
penokee
   / Small gas-powered water pumps #11
I cant recall any negatives about anything linked to the Honda name
   / Small gas-powered water pumps #12
Does anyone know what the inlet/outlet thread is on the little Subaru-Robin PKV101 pump?
I picked one up today for a song compared to the list price, but it was missing the adapters to go from the threaded input/outputs to a hose. It is close to 1" pipe thread but not quite the same...
I did find the overpriced suction hose at Northern Tool is a perfect fit but I'd like to make other adapters.
   / Small gas-powered water pumps #13
It might be 1" NST (national straight thread) which is a hose thread. 1" ips fittings will not work. Quality suction hose is costly, it is the most critical part of pumping efficiency after the pump of course.
   / Small gas-powered water pumps #14
I think you are right about the straight pipe thread...I think it may also be referred to as industrial pipe thread. Now I just have to find where to buy some fittings for it. Northern Tool had a very limited selection and they seemed to fit poorly. The female on their suction hose fit well. I did spring for their suction hose, even though it seemed kinda high ;)
The drought in the NC mountains has severly curtailed my water supply...our spring fed pond has greatly diminished in size. The spring has basically dried up since we are 13" short so far this year on rainfall. The pond has shrunk tremendously which is too bad because the local wildlife get much of their drinking water from the pond and the huge frog population is stressed I imagine. Back in the early spring we had plenty of water, to the point the pond was overflowing, now it is down about 6 ft!
My plan is to place one of those 500-1000 gallon tanks on a hill and fill it with the spring water using the gas pump when we get water again. We don't drink the water when we boondock/camp on the property but it is nice clear clean water usefull for washing. Might even be good to drink, I need to get it tested. Don't have electrical power on the 10 acres either so I was delighted to find a deal on the pump on closeout at Harbor Freight and I had a 15% off coupon too so it came to $150.
Fired it up last night for a test and was pleased with how quiet it is:)
I'm a die hard Honda small engine fan but the Robin Subaru engines appear to be very nicely made, have a big 9 horse one on my log splitter also...
   / Small gas-powered water pumps #15
Skyco said:
... straight pipe thread... have to find where to buy some fittings for it.
Threaded electrical conduit fittings might be useful to make an adapter. This is similar to pipe thread, but without the taper.
   / Small gas-powered water pumps #16
I'm pretty sure the pitch on the 1" hose thread is different then ips threads and the straight threads found on electrical conduit.
   / Small gas-powered water pumps #17
Hoping this thread is not too ancient for a reply:)
I'm pretty much set on the small Honda wx 10 for reasons mentioned here, but unsure of it's potential on my small property which I plan to use for garden irrigation. The specs call for suction at 26 feet and head at 119 feet with 36 gal min thrown in.
Water will be pumped/drawn from a creek that sits about 35 feet below a planned cistern. Pumping distance about 80 feet. I don't need alot of water but would like some guesstimate as to how much output to expect. I'm sure throttle setting has an effect. But will it successfully fill a 350 gallon tank in say an hour?
Reason for confusion relates to loss of flow/diminished output at different head heights.
Thanks for that throttle suggestion. Sure wish the little sucker had a remote kill switch. It's not easy climbing that wooded rocky hill. An electric source is out of the question because of distance.
Thanks guys. Hoping your season is a successful one.
   / Small gas-powered water pumps #18
I'm not one hundred percent sure on this, but it seems to me that the relationship of flow to head ought to be a linear one if we exclude frictional losses. So if you've got 36 gpm at 0 ft head, and presumably 0 gpm at 110 ft head, you ought to get about 24 gpm at 35 ft head. Of course that's straight up. The longer your hose is due to further horizontal travel, the more friction losses will reduce that number, but any reasonably distance shouldn't make significant difference.
So 24 gpm will fill up a 350 gal tank in about 15 minutes.
xtn
   / Small gas-powered water pumps #19
... Honda wx 10 ...
Water will be pumped/drawn from a creek that sits about 35 feet below a planned cistern. Pumping distance about 80 feet. ... will it successfully fill a 350 gallon tank in say an hour?
I Googled on 'honda wx10 pump curve'. Here's the lift/volume graph for that pump.
Honda Water Pumps WX10, WB20, WB30
The chart indicates at 35 ft lift, expect 35 gpm. Output hose friction will reduce this slightly so xn's 24 gpm sounds just right in real-world operation.
I use a similar pump to power my backpack gold dredge. 1.5" blue collapsible discharge hose works fine for output with minimal friction. There is an iron pipe to PVC pipe plastic adapter that is just right to fit the inside id of blue hose, and attach it to the garden-hose pump output.
The important consideration for pumping is to get the pump right down at water level. Suction lift, and air leaks on the input side, kill output much more than lift on the output side of the pump. As for the remote kill - maybe string doorbell wire alongside the hose?
   / Small gas-powered water pumps #20
In this area the Honda is the best seller for use year after year. I know several ranchers that use them.
2017 John Deere 5090GN (A53317)
2017 John Deere...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
207275 (A52708)
207275 (A52708)
2003 PETERBUILT PB330 DUMP TRUCK (A60430)
2003 PETERBUILT...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
