small concrete pour from bag mix , mistake?
   / small concrete pour from bag mix , mistake? #1
roermo
Hannibal MO.
4110 JD
Ok, here is my mistake for the weekend project, I think.
I had a small whole dug, 24 by 20 and 14in deep. It was for a small mail box on which will be made of brick only 24 inches high and 10 inch wide more or less.
I bought three bags of concrete mix and half way through the pour and mixing I figured out it was not going to be enough. The stores were closed. I had two bags of mortar mix that I used and put in ½ inch stone (note sure about the amount maybe 1/3). I used my tractor bucket as a mixing bowel keeping the concrete and mortar apart while mixing. Then kind of mix 1/3 mortar to 2/3 concrete cement and the extra ½ inch stone. This filled up the whole nicely and I was able to strike it smooth.
My question is how much did I weaken the pour and will it hold up. Any idea folks.
Roger
   / small concrete pour from bag mix , mistake? #2
For what your doing, it won't be a problem. If you added some rebar or wire, it would be better, but again, don't worry about it.
Eddie
thanks for the input, that puts my mind to rest some. I did fail to mention I went on the cheap as far as rebar etc. I had a pound or two of old gutter nail that I pitched in very so often just for laughs and some where to put them. Might not help much but sounded good at the time.
thanks again
Roger
   / small concrete pour from bag mix , mistake? #4
You'll be okay.:)
If I use sacked premix I always get some portland cement and strengthen up the mixture a bit.:D
   / small concrete pour from bag mix , mistake? #5
And here I thought I was the only guy in the world who did that.
If I own the property, and I am doing the work myself, I am going to go overkill all the way.
   / small concrete pour from bag mix , mistake? #6
Dave; it looks like you are just as trusting as I am!:D
   / small concrete pour from bag mix , mistake? #7
You guys aren't alone. I do it too, probably way too much as some of my pours 'glisten' when it cures.
Harry K
   / small concrete pour from bag mix , mistake? #8
Oh come on Dave, you really thought you were the only guy who did that?:)
We "do-it-yourselfers" are notorious for over building everything. I always said if one nail will suffice, three is just right!:D
   / small concrete pour from bag mix , mistake? #9
Well, I don't know about that..... One of my uncles was a fine carpenter and had built a handfull of houses mostly by himself. One of them was moved because the owners decided on a bigger home after about 10 years of living in it. He was there to watch it going down the street and his comment was "I would have put a few more nails in it if I knew that this was ever gonna happen.":eek::eek::eek::eek:
The house was fine, and I'm sure it was as overbuilt as it could have been anyway.:D
Brushfox XHD-78 (A53421)
Brushfox XHD-78...
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2017 Ford F-350...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
2000 Mack CH613 Day Cab Winch Truck (A53117)
2000 Mack CH613...
Case Maxxum 140 (A50120)
Case Maxxum 140...
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
