Small Chain Saw?
   / Small Chain Saw? #1
wedge40
Veteran Member
I'm in the market for a small, lightweight chainsaw to trim the trees I've cut down. A friend recommended an Echo CS300. But it looks like those are obsolete. Anybody have any other recommendations. I was looking at the CS341 with a 12" bar, 10" if I could get it. Anybody have a cost estimate for this saw?
Wedge
   / Small Chain Saw? #2
Wedge
I would stick to saws in local specialized stores - either Husqvarna or Stihl. You can't go wrong with either of them.
   / Small Chain Saw? #3
Well,echo still makes saws and just because that model is no longer made I'm sure there is another model that is being made that is very close.
Your friend gave you good advise as to brand,echo makes good stuff,and no professional/homeowner model thing going on,alls theirs are the same.
   / Small Chain Saw? #4
Currently I have Husky but I went to the Stihl store recently and like their saws. Friend of my swears by them.
Chain Saws - STIHL MS 192 T C-E Chain Saw - Professional Tree Service Use - STIHL USA
Here is one I want to buy for my wife. It is light and can be operated by one hand. It is pricey though close to $500 last time I checked.
For myself I would get one of those with "tool free" bar adjustment.
Chain Saws - STIHL MS 280 C-BQ Chain Saw - Mid-Range Use - STIHL USA
   / Small Chain Saw? #5
I picked up a Echo cs360 a couple of years ago and love it. It replaced an older Echo one hand saw that I still have but it doesn't have a chain brake or the anti vibe handles. I have better luck with the Echos for my use as they don't mind if I leave them on the shelf for months then use the heck out of them ,the others seem to like to run everyday or I have trouble getting them started. I also have a Shindiwa 488, a bit bigger but also starts after sitting and suits my needs nicely.
   / Small Chain Saw? #7
I would base your decision on how much you plan on using it. If you only anticipate a few times a year, that is probably a good choice. If you have lots of trees and/or cutting for lots of firewood I would opt for the Stihl as that is what I have and know of as a great saw. I had a Echo and it worked fine for the first year and a half but, as much cutting I was doing I wore it out. Lost two coils, broke the pull cord a few times and then somthing happened that seized motor. Thinking bent valve but not checked yet as I'm having too much fun with the my MS260. Also had a hard time finding good chains for the Echo. Got lots of Cherry and Osage Orange and they would always check the chain (bending the chain blades out). On my Stihl I have yet to need to sharpen the chain and have cut lots of wood since fall.
One thing to also consider is a pole saw. Depending upon how big of limbs you cutting they are great for de limbing. No bending over and its easy to reach into places instead of climbing through all the cut and uncut limbs.
   / Small Chain Saw? #9
Seized motor may not be right word. I can move the piston but it appears to only make a half a stroke like a valve is bent or broke and not allowing the piston to come all the way to the top.
   / Small Chain Saw? #10
Wedge
I just bought a echo cs-530 (20 inch bar)and love it.I used to own stihl 011 and 26 models.The stihls were good saws but mine were always hard to start.Echo also has a 5 year consumer warrenty.coobie
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2007 Boston Whaler w/ Dual 200HP Mercury OptiMax (A51694)
2007 Boston Whaler...
2005 International 4300 Bucket Truck (A52377)
2005 International...
UNUSED CFG INDUSTRIAL SSECAG-Y HYD AUGER (A51248)
UNUSED CFG...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
(2) METAL PARTS CABINETS (A51248)
(2) METAL PARTS...
