Small battery chain saw recommendations
   / Small battery chain saw recommendations #1
saxnbees
Chesterville, Maine
Kioti/NX4510HST, JD/40, Grillo G110 Walking Tractor
I currently have a Husqvarna 350 and an Echo CS 590 Timberwolf. Both have 18" bars. My wife has been cutting up small limbs for years using a hand saw and was never interested in a small chain saw. Recently, she has decided that a small chain saw might be nice to have for her use. I do not think it would make sense to have yet another gas saw, especially one that might not get much use most of the year. So, I am thinking about getting a battery powered saw. It would be used primarily for cutting up limbs for kindling, etc.
What would you recommend for such a purpose?
   / Small battery chain saw recommendations #2
I am constantly trimming tree branches away from my gravel road and also along my property line. About 80% of the time I use a Makita chainsaw, which has extremely powerful and reliable motor and upto 1 hour use on battery pack. Very light chain saw. My wife loves the saw too because its so very easy to handle. I also used this Makita chainsaw to help process small trees for my chipper. I have had this saw 2 years now and has been extremely reliable. The only negative on this saw has been the safety time out after using the saw. Once you turn the saw on, you have about 15 seconds to start sawing, or it will auto shut off. You will just need to get used to the auto shut off safety switch.
Amazon.com : Makita XCU3PT1 18V X2 (36V) LXT Lithium-Ion Brushless Cordless 14" Chain Saw Kit with, 4 Batteries (5.Ah) : Garden & Outdoor
   / Small battery chain saw recommendations #4
   / Small battery chain saw recommendations #5
Wife now uses a Stihl 12" with 36v battery. Great saw. Uses a lot of bar oil, and the bar oil indicator isn't much good like the one was on 2 Kobalt 40v ones she wore out. Kobalt went into factory recall. Could not get another one, either brushed or non brushed.
All 3 saws saw a huge amount of use. She went many days using 2 and 3 batteries per day. Now not doing much. All fallen trees cut up and that 100 yard long pile of debris is gone.
Ralph
   / Small battery chain saw recommendations #6
I currently have the saws in my sig plus a few more that won't fit in the sig.
What's a "small limb"? Less than 6" diameter? < 4"?
How long can your wife hold a gallon of gas with one hand arm extended? Most saws weigh about 8 lbs or more w/ battery
How deep is your wallet?
How much usage and reliability do you need? One forum member uses a Stihl to trim the bottoms of Christmas trees.
Are you already "invested" in a battery system? I've 3 HF lynxx's and 3 batteries. Polesaws and chainsaw.
Stihl undoubtedly makes the best battery operated chainsaws. But too expensive for me for a battery saw.
I've owned a Black and Decker 12" 40V (gave to my Daughter) and own a HF 14" 40V Lynxx. The B&D was like $110 w/ battery and charger the HF was $140 w/ battery and charger.
Both were great. But for the usage you seem to describe something like the B&D 10" 20Volt may do well. My BIL keeps one in his truck. Real handy, real small, inexpensive.
Also for your wifes use you might consider a Sawz-all type tool.
   / Small battery chain saw recommendations #7
If you only plan to have one electric power tool I do not think the brand is a big hairy deal. Most any battery chainsaw should work fine for cutting up limbs for kindling.
Our Lynxx 40v power tools (5) are still working except for the very light line trimmer that got used like a DR two wheel bush hog after 3 years except most are now at my son's place. :) He had most of our 10 year old Kobalt 18v power tool like drill, sawall, circular saw but last week he bought a 24v set and brought my 18v tools back home. I bought the 80v line of lawn care Kobalt tools a coupe weeks ago and have used the self propelled 21" mower, leaf blower but just brought on some bar oil for the 18" bar saw and got a grease gun for the bar nose roller bearing but have not used it yet. The mower came with a 6AH battery and for $300 I could buy a spare 5AH battery or get the 18" chainsaw with a 5 AH battery and charger on clearance for $339. The saw and heavy duty charger for $39 won the day. :)
We now have 4 80v batteries (two 2.5 AH, a 5.0 AH and 6 AH) so I can mow for about 3 hours or use the saw for about that long.
Look for a $150 12-16" lithium ion electric saw like others here have found should be a good option for you since you have good POWER saws already. The longer the bar the heavier the chain often but the heavier the saw is to use and pay for.
The self propelled lawn mower has sold me on battery vs gas at my house and as a bonus they come with jerk-free starters. :)
To answer a few previous questions...
My wife is fairly athletic but in her upper 60s, and like everyone else, isn't getting any younger. So, weight is surely a factor. Most of the stuff she cuts is smaller than 4" so a long bar is not really needed.
I am not currently invested in any battery system. I do have a fairly old 20V Craftsman drill but nothing else. That being said, if you folks think that there is a line of battery operated tools that beats the others, then it might make sense to purchase that brand.
I am not very constrained by a budget, but I also don't believe in paying more for something because of the name. If there is a brand that meets my needs, is well made, and less expensive then I feel it is worth consideration.
If I am reading the responses correctly, it sounds like everyone so far is fairly happy with their purchase and a number of fairly generic brands are included in the posts above.
Is there any brand you think I should avoid? Anything in particular I should consider when buying a cordless chain saw?
Gale, I see that you bought the Kobalt brand. My wife's friend actually recommended their saw and that is what started this search. Is there a particular reason you chose the Kobalt brand?
   / Small battery chain saw recommendations #9
Kobalt 40v (brushed) and 24v (brushless) were in factory recall. Only one available was the 40v pole saw back in the spring when the wife broke an internal cog on her 2nd 40v Kobalt. First one wore out the brushes. Continued with brushes in 2nd one because the brushless switched batteries. They're a good saw. Our two that wore out had A LOT of usage.
Still have Kobalt grass whip and walkbehind push mower. Don't use the mower much because even though light and all, prefer self propelled gas ones because of self propulsion and doing a better job.
In future, will go to self propelled battery powered one, probably a Stihl.
Ralph
   / Small battery chain saw recommendations #10
A timely topic for me. I have an Echo brand gas saw which I loathe. Hard to start, runs poorly, since the day I brought it home. So I use it, but I hate it every day.
I recently had to buy a string trimmer and decided to go electric, if only so my wife wouldn't need to learn to deal with gas mixtures and pull starts which are difficult for her slight frame. And of course if you're going to start buying anything with $100+ batteries, so your homework and plan ahead. So as part of the string trimmer research I researched chainsaws, even though I wasn't sure about going that route, because if you're going to have those batteries, and are thinking about electric chainsaws, then you want to be able to share batteries. Some manufacturers make great string trimmers and so-so chain saws. Definitely makes the purchase harder.
In the end I went with Milwaukee. My first couple of hours with the Milwaukee string trimmer and 8AH high output battery have been great. It's not a light trimmer, but it's solidly built and I get about an hour of trimming on the low setting, which is all I've needed. This model has the Quik-Lock setup, so you can attach the motor +stem to other attachments like hedge trimmers and pole saws. Seems like a great idea to me. (They have another string trimmer model they sell with a 9AH battery but no Quik-Lok, so pay attention if you're shopping).
I was pleased enough with the string trimmer, and had another thoroughly aggravating day with the Echo, that I ordered the Milwaukee chainsaw with 12AH battery and free blower (a promotion - got it at Home depot).
Unboxed it yesterday, it's very sturdily built, but haven't tried it yet. Didn't see anything that smelled of "toy chainsaw". It's heavy, sturdy, and ready for business, will try it this weekend as I have downed trees on my grass ready for work. And now I have two interchangeable batteries, two of the largest Milwaukee sells. The batteries alone retail for about $300+, so if you're going electric you're really committing to some expensive battery technology, make sure you can get the most from it. Try not to drop it :)
I also used to use a corded electric chainsaw a lifetime ago in suburbia. It was actually a great experience, I could always rely on the thing to get the job done, and never had to worry about gas going bad or oil mixes, which is probably why I was open to the idea of a battery powered device now (when an electric cord wouldn't reach past my driveway).
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
Adams 6T Fertilizer Spreader (A53473)
Adams 6T...
2012 Buick Enclave Premium SUV (A53117)
2012 Buick Enclave...
Dump body (A52377)
Dump body (A52377)
1274 (A50490)
1274 (A50490)
2004 CATERPILLAR 836G LANDFILL COMPACTOR (A51406)
2004 CATERPILLAR...
