Small 2 spool valve
   / Small 2 spool valve #1
sqidget
Rhode Island
BX-24
Does anybody know of a 2 spool valve smaller than the cessna 5gpm?
I got the cessna valve from surplus center today. The dimensions of the valve fit the space I have with some extra room for lines, Problem is the power beyond sleeve is 1" sticking out of the valve then with a elbow it is almost 2.25" wider than it was. now it does not fit! :mad: I only need 3 gpm to flow through the valve. Please help!
Thanks Dave
   / Small 2 spool valve #2
That is the most compact valve I know of, sorry:(
Could you post some pictures of you setup? Maybe we can make some suggestions...
   / Small 2 spool valve #3
Thanks Dave
Sqidet, try this outfit. Hydraulics. I browsed through their catalog while looking for the smallest 2 spool valve w/pb for my 140D, and think that the way their valves are plumbed would help keep the "footprint" as small as possible. Please post some photo's as your project progresses. Good luck.
   / Small 2 spool valve #4
There are some really small valves used on lawn tractors that have hydraulics. I've seen several on E-Bay, you might check there.
Thanks for the help so far, as I get more in depth I will post pics etc.
2006 Ford Explorer 4x4 (MPV), VIN # 1FMEU73E36UA28575 (A51572)
2006 Ford Explorer...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2025 New/Unused LandHonor Leaf Blower (A51573)
2025 New/Unused...
2012 TRAVIS 39FT DUMP TRAILER (A52576)
2012 TRAVIS 39FT...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
