sluggish pedal
/ sluggish pedal #1
TrailHermit
Va
Kubota BX 2230
The HST pedal on my bx2230 is sluggish in returning from the forward position. It used to respond smoothly with the motion of my foot but lately it is slow to return. In fact a few times its taken a second or two when I ease off the gas causing some close calls.
I do not have this problem when going in reverse. Any thoughts on what would be causing this?
/ sluggish pedal #2
</font><font color="blue" class="small">( Any thoughts on what would be causing this? )</font>
Lack of grease on the pivot ? /forums/images/graemlins/grin.gif
My B2910 had a similar problem when it was new .... after awhile it just went away.
/ sluggish pedal #3
</font><font color="blue" class="small">( The HST pedal on my bx2230 is sluggish in returning from the forward position. It used to respond smoothly with the motion of my foot but lately it is slow to return. In fact a few times its taken a second or two when I ease off the gas causing some close calls.
) )</font>
Well you can grease it till the cows come home... will not do anything..
Do a search on this topic since it has been talked about a lot. Even my own BX22 did it. This is a common issue here and Kubota does nothing to correct it.
/ sluggish pedal #4
My 23 does it but only uNtil the tranny fluid warms up,I believe mine is a tranny thing not a pedal thing,im carefull until it warms up a bit.
ALAN
/ sluggish pedal #5
does it do it all the time (winter or summer).
/ sluggish pedal #6
My bx 23 does it also . It started at 16 hours on the clock does it hot or cold.
/ sluggish pedal
</font><font color="blue" class="small">( does it do it all the time (winter or summer). )</font>
I got it new last Nov and didn't have any problems with the pedal until this summer after the first 50 hrs service.
After some searching through the forum it seems the problem can be due to different things and adjustments help some or not at all. I'm going to call the dealer and ask them to fix it. It might not help but I've got to try.
/ sluggish pedal #9
I have a BX23. My pedal sticking comes and goes. I've made the adjustments suggested and it does make some difference.
Alos, one time, the rear of the rod, the section with the spring, that the pedal attaches to was covered with dirt, I cleaned it off and it didn't stick as much.
Kubota L3901HST
Kubota L3901HST
MINI FLAT BOTTOM GRAPPLE (A61572)
MINI FLAT BOTTOM...
2018 Dodge Charger (A61574)
2018 Dodge Charger...
2015 Ford F-250 Knapheide Service Truck (A61573)
2015 Ford F-250...
2004 Chevrolet Silverado 1500 4x4 Pickup Truck (A61573)
2004 Chevrolet...
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
