Sluggish operation of Backhoe
   / Sluggish operation of Backhoe #1
Wince
Kubota L39
Backhoe section of my L39 Kubota is very slow and lacks power. The front section is normal. 1700 hrs on the machine, no pump noise. Should I try shims on the relief valve or replace it, as a inexpensive first test.
   / Sluggish operation of Backhoe #2
Check and make sure your BH/3PH bypass valves are set correctly
   / Sluggish operation of Backhoe #3
check filters for any type debre.
   / Sluggish operation of Backhoe #4
After above, Disconnect, check and reconnect quick disconnects. Do the simple stuff first. Wouldn’t adjust pressure before knowing the pressures.
   / Sluggish operation of Backhoe #5
Did you find the problem? The backhoe uses the power beyond from the loader so if loader is ok it will not be the relieve valve. Make sure the two directional valve levers on the back of the tractor are fully pushed in. One lever is for the swing pump and the other connects power beyond to the backhoe. Make sure the three point lift control lever is all the way down.
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52141)
2023 TAKE 3...
Electric Forklift Pallet (A50322)
Electric Forklift...
Walk-Behind Automatic Seed Spreader (A51691)
Walk-Behind...
UNUSED FUTURE MINI SKID STEER HOLLOW WOOD GRABBER (A51244)
UNUSED FUTURE MINI...
2016 Sooner STC 9042 LQ Tri-Axle Horse Trailer (A49461)
2016 Sooner STC...
