SLT 1554 - park brake doesn't lock
   / SLT 1554 - park brake doesn't lock #1
GeriatricGinger
Cub Cadet SLT1554
This is gonna be kinda hard to explain, but here goes..
SLT 1554, the OG engine decided to split the case about 55 hrs in, so I motor-swapped it with a 27HP B&S twin and it's been fine ever since (currently at around 220hrs)..
However, about 2-3 seasons ago, the park brake lever decided to not break, but not hold the brake pedal in place, either. I have had the body off of it a couple times, but still no joy in fixing it.
I have a service manual but only thing I find on parking brake is how to adjust the actual brake, not the latching lever, itself.
Any thoughts or words of wisdom?
Thanks!
/GG
   / SLT 1554 - park brake doesn't lock #2
Some photos of the problem may help us help you.
I'll try to get some photos, but essentially, you depress the brake pedal, push the park brake handle on the dash down, then release the pedal and handle. the dash handle used to hold the brake pedal in place, but that is no longer the case; it just pops the pedal free as soon as you let go of the handle.
4 1/2 150G DRILL STEM 288 JOINTS (A50854)
4 1/2 150G DRILL...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2013 Acura ILX Sedan (A50324)
2013 Acura ILX...
SDLG WHEEL LOADER FORKS MAST W/ 48" FORKS (A51242)
SDLG WHEEL LOADER...
2017 JCB 3CX 15HFCE BACKHOE (A51242)
2017 JCB 3CX...
