Slowest RPMs for the 2302
   / Slowest RPMs for the 2302 #1
Gizmo2
Veteran Member
New York
JD 2320
What is the slowest RPM obtainable on the 2320? Slowest mine will go is about 1200 RPM. My 650 would go all the way down until the engine quit. As a matter of fact the recommended way of stopping the engine on the 650 was to turn the key off (didn't need the key for the engine to stay running) then lower RPMs until the engine stopped. Turning the 2320 off at 1200 RPMs seems a little fast?
   / Slowest RPMs for the 2302 #2
Factory specs are 1300 +or- 50 rpm. Your 650 used the throttle lever to shut off the engine as opposed to an electric solenoid. Two totaly different systems. The engine speed on the new engine is kept higher to keep it from "slobbering" having unburnt fuel from polluting the air. Back in the day they said don't run the engine below a 1000 rpm when idleing for extended periods of time. So there is nothing wrong with your 2320.
Thanks a lot shot_gun.
   / Slowest RPMs for the 2302 #4
Your welcome. Enjoy your new tractor.
UNUSED IRGC80 Battery Powered Golf cart (A47477)
UNUSED IRGC80...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
7-NEW INJECTION HARNESS (A55745)
7-NEW INJECTION...
2015 FREIGHTLINER M2 TANDEM AXLE 24FT FLATBED (A56129)
2015 FREIGHTLINER...
Mini Excavator (A55787)
Mini Excavator...
