Slow Shifting YM276_
   / Slow Shifting YM276_ #1
Anonymous Poster
Epic Contributor
My YM276 is slow shifting from forward to reverse? it takes some times up to several seconds for the trany to kick in after I've moved the shift-lever.
What's up with this??? Is my hydralic fluid dirty? It looks clear? Does it hurt anything to continue to run it this way? I've ordered a new filter but it isn't here yet.
   / Slow Shifting YM276_ #3
Might be a clogged filter. I couldn't guess on whether it hurts anything to use it, but be cautious. The powershifts have a separate powershift pump in the transmission which activates the clutchpacks and also pressure-feeds some of the transmission bearings. But I'm not even sure if the filter supplies that system or not - and looking at the flow charts in the shop manual just makes me even more confused....I believe that the oil strainer in the sump does feed the powershift pump. If I were doing the job I'd be real sure to clean out that strainer. They are known to clog. Remove and clean with a brush.
And if cleaning both filters doesn't fix it, the next place to look is for a leaky O ring in the regulator case which sits on top of the tranny and aft of the steering box. Luckily for all of us, it is rare for a powershift to have an internal transmission problem. Normally it is an oil feed problem.
So this may be a good chance to find out if the replaceable filter does makes a difference in the powershift.. Be sure to post and let us know.
   / Slow Shifting YM276_ #4
I have a GT14 with powershift that does the same thing. If you find out let us know. I have just ordered the owners manual so I know what filters etc. to order so I have been using mine like this.
I have a 186D that had the same problem. I will discribe the fix on mine hoping yours will be similar. Sit on the seat and look straight down between your legs (not at yourself, the tractor)and under the cover is the power shift regulator case ( I have the column shift). At the rear of the case is a diamond shaped cover with two bolts. Remove the bolts and screw one into the end of the sleeve inside and carefully pull out the sleeve. Using needlenose or whatever means remove the relief valve and holder (there are shims inside, don't lose them). Behind all that are two springs, a smaller one inside a larger one. If you can get them out, you should see probably the larger spring is broken (compress it with your fingers, my had a hairline crack). Buy both springs (since they aren't expensive) from a Yanmar dealer. Don't buy one from the hardware that looks just like it (trust me). Replace everything the way it was, check the o-ring on the first sleeve you pulled out for damage and get one if needed. Hopefully you won't have to pull the whole case off. If you do, you need another gasket. This assembly regulates the pressure for the shift clutches and delays the shift so your neck doesn't snap while shifting. The broken spring prevents the proper pressure build up for shifting. I discovered this after the filter cleaning and oil change. I figured it out from my service manual. I hope this fixes it for you. It won't hurt to run it this way, it just won't shift well.
Skin
2010 PETERBILT 340 (A52472)
2010 PETERBILT 340...
2022 Heli Forklift (A51573)
2022 Heli Forklift...
2024 BRAZOS  53FT ALUMINUM STEP DECK (A52472)
2024 BRAZOS 53FT...
2016 MITSUBISHI OUTLANDER SPORT (A52472)
2016 MITSUBISHI...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
